Results 1 to 10 of 27
Thread: FCC grants a waiver allowing hams to use TDMA
    At the request of the ARRL, the FCC has granted a temporary "waiver to permit amateur stations to transmit communications on amateur service channels above 30 MHz using single time-slot Time Division Multiple Access (TDMA)."
    I don't know if this is a good thing or not. Anyone care to comment?
    Full text available here in PDF form.
    It will be interesting to see what kind of equipment, surplus as well as new, becomes available. I'm not too sure I'm a fan of this, or not. I'll be curious to see how it shakes out.
    If nothing else, it will give a whole new dimension to the whiners on the other sites. Lessseee, no code, winlink, CB, IRLP, contests, and now this? Shit, they're going to have to start a new section just to accommodate all the bitching and moaning.
    I can see it now, TDMA is not real ham radio.
    Sorry if I just don't get it. If TDMA divides time into slots and separate the signals of different users by placing the signals in separate time slots, how is single slot any different than a standard repeater? Motorola offers a system with single slot portables and a two slot repeater, it makes sense that there may be two simultaneous users on the system and with multiple repeater slots more users may be accommodated. To me if the FCC only authorizes single slot it's useless as tits on a bull being one user at a time is no improvement in communications effectiveness and no more efficient use of spectrum.
    So what about this I don't understand? BTW I see the advantage TDMA has over trunking, it uses one frequency while trunking uses several to accomplish essentially the same thing, efficient use of spectrum.
    "I can see it now, TDMA is not real ham radio."
    Of course not, it's 2G cell phone technology. (;->)
    Master Navigator AE1PT's Avatar
    Upstate New York
    Don't try to understand it. It's not ham radio, but an attempt by the clueless no-coders to recycle their old analog cell phones as talkies on our bands--bringing us all to the intelligence of CBers and the end of the world as we know it.
    Give a man a fish, and he will eat it. Teach a man to fish and he will spend lots of money on tackle...
    Conch Master W7XF's Avatar
    DM42kj
    IB4TS
    (In bofore Teh Stoopid
    Quote Originally Posted by W7XF View Post
    IB4TS
    Too late.
    DM42kj
    Too late.
    i noticed
    The FCC needs to get with the times, and stop regulating by mode, and instead regulate by bandwidth of the signal. Hams should be allowed to use CDMA, TDMA, etc, as long as it's not encrypted. Narrower bandwidth signals get the lower freqs, and wider signals on the upper freqs; and spread down the middle.
    I knew a girl like that.......
    Actually the FCC already regulates by bandwidth, phone signals for example are limited by the highest audio frequency which determines occupied bandwidth. That's why the ESSB ops got busted for not keeping highs below the customary 3KHz. AM is limited to 6KHz bandwidth which makes legal ops sound kinda yellowy with that 300Hz-3KHz telephonium yawdio. When it comes to data modes, basically occupied bandwidth is a function of data rate so the upper limit is specified. This saves operators the trouble of calculating whether or not the intended data rate meets or exceeds the bandwidth limits. Bandwidth is not specified on the microwave bands so progressive packet nodes/BBSes use high speed microwave forwarding links.
    Huh? Show me where ESSB ops with a wide clean signal get busted? Many AM folks run 12 Khz wide. I have run 6khz wide with a clean signal, but only if I don't bother the "neighbors". I use the panadaptor view on the Flex, so I can see what is going on.
    Don't do it often, as it's not efficient. 4Khz gives me a great "HiFi Voodoo" sound, but I usually run at about 2khz wide +/-, especially if I am not running an amp, tailored to my voice characteristics. If I'm ragchewing with an ESSB group I will bring up problems with other's wide signals... too much bass is stupid, unless you sound like Harvey Fierstein.
    http://youtu.be/5D_vvsiJUxw
