Results 1 to 10 of 17
Thread: Amplifier re build..
    Hi all...I have been busy these past few days doing a re build on my old HF shack amplifier..I built this unit a few years ago to cover 80-10 meters but in all that time I only ever used it on 7mhz..As my building and wiring skills have improved I pulled out all the original wiring, grid protection circuits and the tuned input and pi output coils...I made up a completely new front panel..
    I completely re wired the amplifier using my current style, and disposed of the grid protection circuits which I have found unnecessary with the Russian GI-7BT triodes...I made up a simple adjustable Pi input network and a new coil for the Pi output...
    I started on Monday and finished today...Switched it on and all functions work perfectly..I havn't put any RF into it as yet as I am re vamping my shack...Needed a good cleanup..
    The following pics are the old amplifier then the rest the finished overhaul..Enjoy..
    I will now upload the re modeled amplifier..
    Bob..VK3ZL..
    Ok This is the completed 7mhz 2 x GI-7BT amplifier....If you look at the tubes you will see that I have used coolers from GI-46B tubes....These coolers are much more efficient than the originals and are a perfect fit..Pics show the re vamped Pi network with a simple home brew coil..I retained the vac cap 3-200pf and the 3 gang loading cap..Behind the front panel is all new wiring..Step start and bias control circuit etc..
    I am really pleased with the outcone...Downer is that there are a few spare holes in the chassis but a few bolts and nuts, pop rivets etc will cover them up...
    I have included a pic of the HT transformer...It came from some old industrial equipment..Beautifully made C core..Secondary is rated 900 volts at 1.5 amps..Voltage doubled it gives around 2450 volts and drops 150 volts under an 800ma load...Picked it up for $5...I just wish there was more of that stuff around...
    Ok that's all of that project....I am also about to complete a new 6 meter GI-46B prototype...I will post that here an a couple of weeks....After that I am building myself a new 160 meter shack amplifier...I currently run a water cooled single GS-35B on Topband...As I am getting up in years I have decided to revert back to air cooling...Old age, 4kv HT and water condensation on vinyl water hoses are not a good mixture, so time to take stock, make things safer and sit back happy....
    Enjoy....Bob..VK3ZL..
    As usual it is a beautifull set of piccies Bob, and a pleasure to see how much detail you put into the amps, i would have been closer i might have opted for one of yours in place of the Heathkit SB-1000 i rebuild.
    Keep us fed with thse piccies, keeps us off the street and out of trouble ;)
    Damn, Bob. That is some more outstanding work. I never get tired of seeing your work.
    Where do you get your tubes? And, what do the GI-7BT run down under? I wish I had the time and metal skills to put something together from scratch. Everything I ever did was using commercially available enclosures and adapting them. I could use one of my skills to make a nice enclosure, but I doubt oak would be a good choice.
    Orca Whisperer N1LAF's Avatar
    Ledyard, CT
    Professional Schematic Generation in standby...
    This is all I can get from the photos.
    Looks good - as always!
    Nothing I can add here... Just gorgeous.
    Yeah, and will you please stop doing that? It makes the rest of us feel inferior.
    Senile Member WA4TM's Avatar
    I'll second that statement!!!!!!! I still have problems with static on FM broadcast radio!
    Looking darn good Bob!!!
    To be honest, I feel inferior when I see someone that can color and stay inside the lines. I can't find the words to describe what I feel when I see Bob's work.
