Looking to put a decent bench together on a budget?
Be on the hamfest lookout for Tektronix 7000 series mainframes and plugins. Until late last year I had absolutely no idea what this series of gear was all about and it's too good not to share.
Tek made a number of different oscilloscope chassis and measurement plugins in the series from the early 70's until the mid 90s. It was expensive as hell at the time, fairly affordable at present as surplus - and the best part is that a piece from the 70s will work with a piece from the 90s.
Mainframes: Bench and rackmount models were offered. Most came with an on-screen alphanumeric display (which I'll get to in a moment). Of the benchtop series, the two I would look for are the 7603 (a 100MHz unit with a wide CRT) and a 7104 (1GHz; widest bandwidth of any analog scope ever built).
The key to these instruments' flexibility are the many plugins which are offered. The 7603 (at top) has a spectrum analyzer installed while the 7104 underneath it has a standard vertical amplifier/timebase complement.
In subsequent posts I'll discuss each plugin type and any associated quirks, hints and needed accessories.
