View Poll Results: What antennas do you have?
Voters
36. You may not vote on this poll
  • Indoor antenna (I.E. attic dipole)
    1 2.78%
  • Single wire antenna less 25 feet high
    2 5.56%
  • Single wire antenna, 35-50 feet high
    7 19.44%
  • Single wire antenna more than 50 feet high
    2 5.56%
  • 2 or more wire antennas, all under 35 feet high
    7 19.44%
  • 2 or more wire antennas, 35-50 feet high
    10 27.78%
  • 2 or more wire antennas, all higher than 50 feet
    1 2.78%
  • Single tower with tri-bander, 30-50 feet high
    4 11.11%
  • Single tower with tri-bander, more than 50 feet high
    1 2.78%
  • More than one tower, with several mono-banders
    1 2.78%
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Antenna survey
    Antenna survey
    I'd like to get a feel for what Islanders have for antennas.
    Please select from the poll choices and then give a brief summary of how you feel you do when it comes to working stations, both domestic & DX.
    For example: "Don't seem to have much trouble working continental USA, but Europe and Pacific are issues."
    Or: "Near top of Honor Roll. There's almost nothing I can't work."
    Amp, or not?
    Too bad there is not the option to choose two. IE: 2 or more 35 to 80 feet and a 10m ant 9 feet above a structure which starts at 10 above ground.
    I thought about allowing more than one choice, but with 10 choices, I figured that would be a bit too much.
    Understood. I like antennas. Always have. Beautiful addition to any home. It just isn't a home without an antenna or two. I feel bad for all the people who have to go through life without ever knowing the joys of antennaism.
    What? Yes. I'm totally serious.
    Jan 2008
    DM79ms
    Mobile :: Various Ham Sticks, single trunk lip mount..
    Two wire antennas (40m dipole, G5RV jr.), three VHF verticals (6m, 2m, 220 MHz), one UHF (70 cm) vertical and a 10m Moxon. All but the UHF vertical are home brew. Also a Cushcraft R8 HF vertical but it's yet to be assembled and erected.
    A 460' random wire that peaks at 80' in height.
    A 125' random wire peaking at 85'.
    20m doublet dipole that is sitting vertical right now until I repair the loose leg. One end at 80', one at 30'.
    Antron A99 for 10meers.
    Giant metal building as counterpoise and ground.
    Took all the VHF/UHF stuff down and using small outdoor amplified TV antenna for the scanner.
    There is a 13 element 2m monobander sitting in a room and a 4 element 2m mb'r that you could hold in your hand sitting in the same room.
    Not even going to mention the 6 element FMBCB antenna I use almost daily with a Yamaha CT-410II.
    Conch Master
    Mar 2011
    Home
    102 ft Doublet at 50 ft
    260 ft dipole at 70 ft
    Mobile
    Chameleon HF multi-band whip
    6 meter whip
    "Love Trumps Hate."
    Uh Huh, What Love?
    2 HF verticals, 1 wire, 1 V/UHF vertical up. 2 HF verticals (1 in need of repairs, 1 just for parts), a new-in-the-box VHF vertical, & the remains of a Mosley beam in storage.
    I have a single antenna, but two wires on it. Inverted V fan dipole, at the peak of my roof.
