Results 1 to 5 of 5
Thread: Tools Explained
    Tools Explained
    Common Tools Explained
    To the uninitiated, the workshop can be an intimidating place, full of tools you may not know what to do with. To help, here's a helpful explanation of common tools and their uses.
    DRILL PRESS:
    A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL:
    Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned cleco calluses from fingers in about the time it takes you to say, "Oh sh*t!"
    ELECTRIC HAND DRILL:
    Normally used for spinning pop rivets in their holes until you die of old age.
    SKILL SAW:
    A portable cutting tool used to make studs too short.
    PLIERS:
    Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER:
    An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW:
    One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS:
    Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    WELDING GLOVES:
    Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH:
    Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
    TABLE SAW:
    A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK:
    Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bum per.
    EIGHT-FOOT LONG YELLOW PINE 2X4:
    Used for levering an automobile upward off of a trapped hydraulic jack handle.
    E-Z OUT BOLT AND STUD EXTRACTOR:
    A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST:
    A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
    A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
    AVIATION METAL SNIPS:
    See hacksaw.
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
    PRY BAR:
    A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER:
    A tool used to make hoses too short.
    HAMMER:
    Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
    MECHANIC'S KNIFE:
    Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
    SON OF A BITCH TOOL:
    Any handy tool that you grab and throw across the garage while yelling "SON OF A BITCH" at the top of your lungs. It is also, most often, the next tool that you will need.
    Nov 2008
    arnoldsville ga
    I have all those tools except for the engine hoist........ The 2 ton chain fall over the tree branch serves the same purpose though...
    Thats right... I don't have a son of a bitch tool....
    Mine is a Muther Phucker tool....
    I don't have a son-of-a-bitch tool either. I do have some Jesus clips, though. As in "Jesus, where'd that clip go??"'after it flies across the room during the removal process.
    Conch Master W5GA's Avatar
    I have lots of gawdammit tools.
    One of the most important tools and the one Tim Allen forgot is the Round Tuit.
    Surely you have said "when I get a round tuit" but never quite knew what
    one is or where to get one.
    That's something you won't find at the hardware store, it is custom to
    every mechanic and must be made by that particular individual himself. A
    round tuit is a powerful tool, so it comes with some "product warnings".
    While light and compact enough to be carried in a shirt pocket,
    preferably the one over the heart, and is recommended the mechanic
    carries it at all times, it has the power of a punch press and can rip
    like a power saw. It is useful in most applications, but NEVER use one
    when dealing with a "honey do" project! It has been known to maim and
    even kill although indirectly.
    When activated it gives off dangerous electromagnetic waves which affect
    the female mind. If switched on within range of the wife, those waves
    affect her brain, sending her into a blind, violent rage, resulting in
    great harm to the husband. If the wife happens to be holding one of HER tools
    such as the proverbial rolling pin, the mechanic's skull may be caved in,
    and worse, a butcher knife. Decapitation, castration or dismemberment,
    the male member being first choice may be the result.
    Use one with caution and respect and NEVER let it fall into the wrong
    hands, specifically the wife's. They tend to use it as a kitchen implement
    resulting in the mechanic's resorting to Mickey D's. UGH!
    If this particular mistake should me made, further caution is advised and
    measures taken to prevent a recurrence. This mistake can be compounded by
    the mechanic's going out for Kentucky Fried Chipmunk or Chinese, but
    ordering a pizza or other delivery is DISASTROUS! The wife will easily
    catch on to the wonders of this useful device and build one of her own.
    Her version can be used ONLY by the female and the waves it gives off
    affect the MALE mind. They are hypnotic, sending the mechanic for takeout
    or to the telephone to order. They also wipe out short term memory,
    leaving him to wonder "How the hell did this happen?". The waves are also
    magnetic, drawing money out of the wallet, and combined with short term
    memory loss he wonders where the money went. All this wondering drives a
    man insane.
    Remember, a round tuit is like golf, Gentlemen Only Ladies Forbidden!
