INterested in getting a different antenna build i stumbled on another forum i come on a new design of the old trusty end fed antenna, older as me, but not with a 1:9 balum but a new design 1:49 balun and resonant wire after that multi band.
In my piccie you see the 800 watt balun 2 times FT 240-43-61 stacked together and taped with glass fiber tape and the windings, see here for more details
THis is for the smaller core the same as for the larger cores the ft 140 is smaller and good for 100 watts PEP.
Over the center conductor and ground you need a 100 or 150 PF 500 volt or beter 1000 volt condenser, to make 10 work better wire lenths for the different models here: http://pa-11019.blogspot.nl/2012/04/...tennas-35.html scroll down a bit.
http://www.hyendfedantenna.nl/joomla...-hyendfed.html here is the adress and site of the guy's producing them in the Netherlands for the ones that don't want to make one themselves but rather buy one.
