Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Small parts exchange
  1. #31
    Cores and pots...
    1) Dan's Kits and Parts is a good source. There's also a hamfest vendor in my area who brings a lot of them to the various venues. I'll have a look next time and get contact info.
    2) What taper (linear, audio, log, reverse log), single or multiple gang, shaft diameter? Details, man!
  2. #32
    May 2016
    Lake Michigan Beach MI
    Cores and pots...
    Linear would be best. Don't care about anything else.
    I need to attenuate a noise sensing antenna in certain situations. Will help achieve better phase cancellation of local noise sources.
  3. #33
    I think I have one in the junk box. Will look this week.
  4. #34
    Cores and pots...
    Thanks man, will do.
  5. #35
    I was taking my old Yaesu FT 470 out of storage and I have a rebuilt FNB -17 pack that was with it changed from Ni-CD to Ni-Mh .......what wasn't with it was the plug in charger for said battery pack.Anyone have a charger that they do not need? I was looking in the thrift stores out here if I can get a charger but no go with that idea because the plug that goes into the battery pack is impossible to find! Let me know if you want to part with it and and I'll send you what money you need
  6. #36
    You want to repair by replacing the plug, eh?
    Looks like a 2.5 mm mono male phone plug.
    Adapters exist at box stores to check the size.
    You may have headphones with that size.
    Replacement plugs are on Mouser, etc.
    Kobiconn 2.5 mm Male 2 (TS, Mono) Phone Connectors – Mouser
    A veteran of the RadioShack Parts Drawers.
  7. #37
    There's several listed on eBay at the moment from $10-$24USD.
  8. #38
    I'm concerned about the 2mm vs 2.5mm
    Check it with a common 2.5mm
