Results 1 to 10 of 21
Thread: swr and watt meter
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    swr and watt meter
    Anyone know if it hurts anything to leave a swr and watt meter hooked up while transmitting?
    Quote Originally Posted by kk4fpx View Post
    Assuming the meter is of decent quality (low insertion loss), it doesn't hurt a thing.
    I have several Kenwood SW-2000s with sampling heads that are attached to various VHF/UHF transceivers, HF transceivers and amplifiers in the shack. They're never disconnected. If I had a Bird 43 or other lab-grade instrument it wouldn't be used as a "shack accessory", however.
    Mine are built into my tuner and so are always hooked up when I'm transmitting. Never hurt anything. I think it's a good idea to keep one hooked up, in fact—it will help you spot a potential problem with your antenna system before you fry the finals on your radio.
    I keep a Daiwa CN-801 inline. It has saved my butt many times.
    Conch Master W5GA's Avatar
    If it's not hooked up when you transmit, it doesn't tell you anything.
    Well, with these new fangled solid state finals you gotta worry. With the kind of finals I use all you need to do is look at them. If you see the plates glowing bright orange-yellow it might be a sign that something is a bit out of tune. If they are just glowing a ruddy cherry red your good to go and you can probaly lean on them a bit harder..
    Quote Originally Posted by W5GA View Post
    Has anybody told you you're such a smart-ass, you could sit on an ice cream cone and tell us the flavor?
    I kid, I kid!
    Or you're running a 4x1 WAY over it's limits on linear AM! Such a pretty glow!
    Go ahead and leave it in line all the time. Good monitor for what's going on out there.
    You ain't got no watts iff'n you don't have dem Bird watts! ;)
    No excuses.... :rofl:
    :rofl:
