Didn't think about the ATF but I guess it makes sense since it's supposed to keep the trans clean too. I have half a bottle of Honda ATF I was going to throw out but I'll save it for the carb cleaning.
I had a 93 civic with a carb. No VTEC but good on gas.
I had a '76 Accord that had an actual choke on the dash that you had to pull out when starting the car.
My dad's 1985 Datsun pickup had a choke... And a column shifter!
He has a datsun diesel crew cab now. Floor shift and of course no choke (since its a diesel)
So, get busy and fix it. You can find all the parts online. Check out some of the references I posted and Google for tons more.
get that bad boy running again. Start with a carb cleaning and if that don't work do a rebuild. Don't forget to replace your gas lines and filters while you're at it.
Once I finish with the weed trimmer I've got an old Homelite gas blower to fix and a Poulan chain saw to fix.
I tried sears, they said they don't carry parts for that old model anymore. I'll start looking online to see what I can find.
I need a new plug wire and probably a carb rebuild kit.
