Here's the latest news on the gas string trimmer that I have been repairing. Just to bring you up to date the problem is that it doesn't take fuel properly. When I press the primer bulb it won't suck gas. If I choke the engine and pill the started enough times I can sometimes get enough gas into it to get it to run for a couple minutes before it eventually conks out. Sometimes if I am running it and I tilt it one way the mixture will run to lean, if I tilt it the other way it runs rich.
It uses a Walbro carbuerator. Just yesterday I rebuilt the carburator, I replaced the screens, welch plugs, regulator needle, diaphragm, gaskets, etc. I also replaced the fuel lines and filter. The result ?? The primer still won;t suck gas and it still runs like a piece-o-shit.
The only part I didn't replace was the check valve that sits directly under the primer bulb. As far as I can see that is the only remaining part that can be causing the problem. Everything else is either new or just like new. Only problem is that I need to figure out if I can just replace the rubber check valve or, if I have to replace the whole cover + check valve. That is about the only part left that can be causing issues with fuel intake. Now, finding a dealer that has these particular parts. Tthey seem to be sort of scarce.
In any event , that is the latest episode of the quest to get the trimmer working again,
