Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: frequency question
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    It's the Radioshack htx-10.I haven't got my htx-100 yet.All it's got is a fine tuning knob.
    Conch Master W5GA's Avatar
    If you're getting lousy signal reports, you're probably on frequency ok. If you were off, you'd be told about it because you'd be mostly unintelligible. If you have a really low antenna, or a lot of loss in the antenna/transmission line combo, you'll get lousy reports. Also, except for one or two days recently, 10m has been pretty much a dead zone. MUF hasn't been that high.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I finally got my htx-100.It seems to tune in to the transmittinf frequency better. After a day of use I did the mic mod for higher mic gain seems to work better.
    IMO, the '100 was the better rig. Its RF/AF board is similar to the HR-2510/2600, albeit with a better SSB filtering scheme.
    I made a bunch of mobile contacts with my HR-series rigs throughout the late 80s into the 90s...and afterwards pressed them into service in a multiport packet radio BBS/gateway. They ran nonstop for over 10 years without a failure.
    At first, I thought it was about how often he should have sex.
    There's an app for that.
    Good advice right there. I've been burned by that one a time or two.
    That's what made the Eico 753 so much fun. You couldn't turn off the RIT. Bigger problem than the drift.
    That wasn't a "problem," it was a feature—Eico's patented Lid-O-Matic tuning!
    Was the station DX?
    If so, he may have been expecting stations calling him to be furthur offset from his frequency.
    (Was he operating Spread Spectrum?) ;)
