Page 51 of 65 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 650
Thread: Intros
  1. #501
    The ATU on that thing uses the same forward and reflected power meters as my ST-3B.
    Correct. I have a rare ST-3C ("Commercial") tuner, two of the ST-2Bs and three -3Bs...meter reuse throughout.
    Note the "Swan" logo meter in the amplifier. Must have had a bunch left over from the 1500X.
  2. #502
    I like the dual-meter set up a lot better than a forward/reflected switch or one of those god-awful cross-needle things that MFJ uses.
  3. #503
    That is neat. With all that what the hell are you talking about repackaging some heathkit for? If you are all that board get a signal one cx-7. I wonder if that tuner was an scg, no meters on/off and some leds main led came on when it was tuned. I saw the pics of your op position neat stuff, I see you like Drake7 series. that was my first serious set up- TR7/R7 etc.
  4. #504
    Is the st 5 just a tuner able to handle more watts than the st 3?
  5. #505
    Quote Originally Posted by KC4TIR View Post
    1) Because I can, and because the outcome justifies the effort. ;)
    2) A friend of mine (ex Drake engineer) used to make lots of money repeatedly servicing the early Signal One stuff. Pass;
    3) The tuner I have is definitely not an SGC unit. Two completely different design approaches.
  6. #506
    The ST-5 uses a toroid inductor and edgewise meters, as opposed to the ST-3's PI-Dux coil and standard sweep meters. The aim was to shrink it to a size small enough to fit into its suitcase. Power handling...it's capable of coupling the output of an Astro D to loads of different impedances though you aren't going to run a kilowatt through one. Core saturation of the inductor is the limiting factor where applied power is concerned.
  7. #507
    I meant the tuner in my old AstroD. I will say the signal ones are the only radios I have that can be working fine until you turn it off, then you wonder if it will work when you turn it back on.
  8. #508
    There is an ST 3B on ebay, meters sure look better than ST 5. Eham rates it high also, so they must be pretty good.
  9. #509
    Note who wrote the most recent review. The call sign might look familiar.
  10. #510
    Haven't checked over there - I may go add a comment.
    My ONLY gripe with the ST-3 series is that the shaft couplers and fiberglass shafts used to connect the tuning knobs to the variable capacitors will occasionally loosen up and result in a bit of play, which prevents "precise" tuning adjustments. The fix is easy, though - open 'er up and gently tighten the hardware.
    The ST-2B and -2R are different animals altogether, and don't have an antenna selector/tuner bypass switch. Which is one thing IMNSHO they truly need.
