Results 1 to 10 of 16
Thread: Industry Canada to allow use of 5 Mhz
    Well ....it took quite awhile but Industry Canada has acted on a Radio Amateurs of Canada request proposal to allow Canadian Amateur radio operators to use frequencies in the 5 Mhz band on par with U.S. and other administrations
    Hopefully if all goes well, Canadian OP's could have operating permission by fall
    Industry Canada inormation URL: http://www.ic.gc.ca/eic/site/smt-gst...f10381.html#a1
    Interestingly,Industry Canada will currently allow operators on this band for the cost of an "experimental" licence ..... :-?
    Why,driving into a brick wall at 60 miles per hour, would I expect it not to hurt! :roll:
    How long before the 313 antics make it down to 60M?
    I assume if one particular stupid Canadian operator who hangs out on 313 were to move to one of those 5 Mhz frequencies it would prove to be an equal mess!
    Master Navigator
    Quote Originally Posted by VE7DCW View Post
    Then, 60 meters would be just like cable T.V. -- you would have the Comedy Channel, the Emcomm Channel, the WinLink Channel, etc. :)
    I wonder if we will ever see 70 MHz allocations, like those of our ham brethren across the pond.
    Quote Originally Posted by wb5ydk View Post
    Supposedly, Yaesu made a 70MHz module for the FT-726R. I would love to lay my mitts on one of those, even if for no other reason than possible 6-to-4M transatlantic F-layer work.
    Oct 2011
    Hillsborough, NC
    Supposedly, the FT-847 is usable at lower power on 4m with some filter mods.
    Jim
    Quote Originally Posted by KG4NEL View Post
    I don't need another transceiver - and cannot transmit on 70MHz regardless. But this raises an interesting question: How well does the '847's receiver work in that region of the spectrum?
    I don't know but perhaps a simple tuned preamp is the direction one would go in.
    Orca Whisperer N2RJ's Avatar
    USA
    Probably never. Can't use a "toob with handles" down there. 100 watts ERP only.
    I can't even use a beam or other gain antenna.
