Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Hum in tx
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Hum in tx
    I have been told by two stations that I have a bad hum in my transmissions.Any ideas?
    We're going to need a lot more details. List of equipment, etc.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I have a Radio Shack HTX-10,25 watts.It's hooked to an inverted v antenna,and hooked to a MFJ 4312 powersupply.
    Quote Originally Posted by kk4fpx View Post
    My first suspect would be the Mighty Fine Junk power supply. Can you try powering it from a car battery or another power supply?
    Yes. Test it on another power supply. If that fixes it then you'll need to change the big caps in the PS. This can be dangerous as you'll need to make sure they are completely discharged. Yep, they pack a smack that could kill you. Don't ask me how.
    A band-aid that might work for a while would be to ground the PS and radio separately.
    As for the antenna, some people are for grounding the shield leg, some are not.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I was just talking to a station on California.He told me to put my finger on the mike plug . He said that it worked.next?
    Ground the radio and PS separately.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Not sure how to do that.
    http://www.hamuniverse.com/grounding.html
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I saved the site.I'll go over it later.Thanks
