Results 1 to 10 of 29
Thread: 10 meter beam
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    10 meter beam
    Anyone know if its ok to use two different dia for the REF and the DE?
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    It's a two element.
    Yes, it is. You won't really get into problems with L/D ratios using normally available element tubing until you get into the VHF region. One can model the effects using NEC or similar software.
    Orca Whisperer N2RJ's Avatar
    USA
    It's kind of interesting because SteppIR kinda does this with its trombone style elements.
    I was talking to K7IR and he was telling me that with the DB36 they were basically "modeling the piss out of it" and they found that not only did they save space and the gain difference between a full size and the trombone was not that much... but that the F/B was actually BETTER because the trombone had better capacitive coupling with the other elements close to it. Now I wish I got one... well, there's always room for another tower. :)
    Tapered elements like you get when you use telescoping tubing can affect how an antenna behaves but I don't think that using a reflector that's a different diameter from the driven element would matter much. It might tune a little differently but there would be no major difference in the pattern.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I'm trying to use what I've got on hand.I think I'm going to have to use the bigger dia for the driver because of the length.How close should the two haves of the driver need to be and is the gap concidered part of the overall length?
    Quote Originally Posted by kk4fpx View Post
    At HF, a difference of 1/4" or less is desirable. The gap is part of the overall length.
    What type of matching arrangement are you considering? If you employ one that allows for grounding of the driven element to the boom, the antenna will be a lot less susceptible to static noise (QRN).
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I am planing on just useing a poor mans coiled balun and hope I acn get a match.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Never mind.I don't have as much tubing as I thought.So.... I'm going to try a horizontal vee dipole.
    Hmmm. I've made these for 6 meters... they are easy to do.
    http://www.moxonantennaproject.com/index.html
