Results 11 to 20 of 25
Thread: inverted v antenna
  1. #11
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Second try.Yes I'm using coax feed line with 6 inch 6 coiled balums on all my antennas.I'd like to try and contact some of you on 28.400 when get it back up.I'll be K4ECE.
  2. #12
    Quote Originally Posted by kk4fpx View Post
    Some of the older Islanders have the same problem, however, it has nothing to do with antennas.
  3. #13
    Mar 2008
    San Vicente, Alicante, Spain
    If you use balanced feed line and a link coupled tuner you need only cut it for 160, 75, or 40 and you'll be good to go on 20, 15, and 10. case and point, my inverted vee doublet) is cut for 75/80 metres and via the tuner it tunes, loads and performs great on 75, 40, 20, 15 and 10.
    But if you want to go with a coax fed and no tuner you can do a fan dipole or something similar.
    I could never hold reasonable SWR on 40m with my 75m Vee. Worked wonders on 75/20m though. I have used fans as well with good results. Ended up putting up a loop for 75/80. I found myself transmitting on the loop and receiving on the Vee.
  4. #14
    National Park N.J.
    Huh?
  5. #15
    Orca Whisperer N2RJ's Avatar
    USA
    There is a catch. Yes you can do that but you'll have nulls on the higher bands. It won't be omni.
    But yes, it works in a pinch.
  6. #16
    Master Navigator KC9ECI's Avatar
    Wiscowsin
    What's a balum?
  7. #17
    Quote Originally Posted by KC9ECI View Post
    What's a balum?
    It's what you do when when water starts coming through a hole in the bottom of your rowboat :)
  8. #18
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Sorry I miss typed,I meant balun.lol
  9. #19
    I recall an article by W4RNL (SK) showing antenna plots that show an Inverted Vee cut for lower bands and used on higher frequencies also quickly becomes a cloud warmer... When to far removed from the fundamental frequency it's cut for.
    Not too useful on 10 meters. Make it a fan.
  10. #20
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Got my fan inverted v back up.instead of single point conection I seperated the 40 meter from the 10 meter by 6 inches.I haven't checked the swr yet but I made a contact with El Salvador on my 25 watt Radio Shack 10 meter transciever.
