Results 1 to 9 of 9
Thread: FT-101 in contest action
    Master Navigator KC9ECI's Avatar
    Wiscowsin
    Started out the contest with my Icom 706mkIIg and after 5 qso's had an issue with rf feedback and the LDG tuner. No time to troubleshoot so I switched over to the FT-101 and the MFJ 949 and continued on 40m. I was eventually joined by Greg, W9IKU and we shared the frequency and rag chewed a bit during lulls in activity
    An original '101' - not a B or later suffix? Rare bird...
    Wiscowsin
    Yep. Eau Claire radio club auction several year ago. I stayed to the bitter end and was one of less than 18 or so people left. This was the last thing to come out from under a table. Only one other guy bidding and Ellen AF9J egging me on and I got it for $80 or $85. Came with a spare set of tubes. It wa the only thing I bought that day.
    A coworker/ham friend of mine related an experience he had at an area truckstop/CB radio shop in the early 70s: FT-101s were being carted in and out of the place by the dolly full. Estimates put overall sales of the 101/B/E/F series in the U.S. to be in excess of 1 million units, yet at the time there were ~500,000 licensed U.S. hams.
    Quite a few CB people in this area used a 101-series transceiver. Another guy south of Canton ran a converted FT-901DM on 11 and the father of a nearby friend had a loaded TR7 - this in 1980 when the rig by itself cost $1500.
    As far as I know, none of them ever joined the ham ranks.
    Better than running a sweep tube 11 meter amp... cleaner signal!
    Well, unless you fooked with it.
    Conch Master W5GA's Avatar
    The 101 is a neat rig to play with, but I wouldn't recommend using it in something like CQWW down in the middle of the crowd...the rx will fold up like a wet blanket.
    "Quite a few CB people in this area used a 101-series transceiver."
    Interesting you brought that up, just clip the yellow wire and the relay will close with the band switch in the 11M position. I knew The Breeze, a CBer smarter than the average bear who used one and the matching FL-2100 amp when he need that extra kick. The kid really knew what he was doing, AM sounded fine as did SSB with not a speck of cereal, that is to say a clean signal without splattering across the band like some others that sounded like they were using a cheese grater for a microphone IF you could figure out which channel they were on.
    Once upon a time I had a 101EE but not licensed for HF it made a nice receiver, a pretty good one too. BTW I like my Mark but I'm rather annoyed at now being sans antennas but maybe some day I'll get even.
    With proper modification those 101's can sound awesome on AM with a nice freq response from DC right on up to the upper fringe of human hearing and beyond.
    The only problem with that is excessive occupied bandwidth and since "AM" is carrier inserted sideband SSB would be broad as a barn door as well. That's what got the WSSB crowd in northern NJ in trouble when numerous complaints were filed and the FCC sent out wolf tickets. Not a problem for those who know what an EQ or something as simple as a switchable M derived pi section low pass filter is for when you don't have a good slice of the band all to yourself.
