Results 1 to 10 of 18
Thread: alinco hand held
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    alinco hand held
    I picked up a alinco model dj-f1 at a hamfest.I was trying to set it up today.Everything worked ok except when I put in the 146.520 freq,when I pushed the ptt,it says "off".I thought that was only when you were out of the transmitting range.Anyone know whats wrong?
    The VFO on that unit can be field programmed top restrict the transmit frequency range. It's possible that the previous owner did, so try resetting it. The manual is available on Alinco's Web site.
    Make sure you're in simplex mode. If not, and it's set duplex at -600, you will be out of band on xmit. At that point the radio says nyet.
    Funny, I was just coming back to say the same thing. Good call, Ed.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I've already printed the manual out.I did the factory reset before trying to add in my frequency's.The default is + 600,and the 146.52 does show a plus.I don't know how to make it go to simplex on that freq. without having to reset it everytime I need to use that freq.
    Well, your Eminence, even a blind squirrel finds an occasional nut, usually his own, but, what the hey?
    See page 22, "Setting Offset (Shift) Direction"
    You kidding me? Your own are always the best ones to find. You don't want to lose track of 'em, after all.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I just read page 22.Not sure if I understand it,but as soon as I get it off the charger I'll see if I can get it on simplex for that freq. Thanks
    Some of the amateur gear manuals are a mite confusing, even to those who write technical documentation for a living. Almost all VHF/UHF gear manufactured in the last 10 or so years has "default" repeater offsets (which are based on current band plans) programmed from the factory. If a prior owner changes these for any reason, restoring the defaults can occasionally result in a few uttered cursewords. The menus on some radios are NOT intuitive...and the poorly-written manuals don't help matters.
