Results 1 to 10 of 26
Thread: New innovative bridge placed in the Netherlands
    http://nos.nl/artikel/347223-a27-kri...gaviaduct.html
    Video of the placement is there.
    Longest bridge lightweight bridge in the world.
    140 meters long in one section, 6.2 meters wide, made from steel and composite material, good for the heaviest traffic.
    Weighing in at 200 metric tonnes.
    A normal bridge would weigh 7 times more, the new bridge is 20 times stronger and needs little maintenance.
    Lots of interest from all over the world for this new concept.
    Interesting tech, but kind of boring visually.
    Use some paint to fresh it up ;)
    No problem to make a different configuration, it is the innovative use of composite materials and combined with inner steel that makes it news certainly the low weight.
    Forum Addict KC2KFC's Avatar
    Sep 2008
    Still I agree with Carlo. It's visually boring.
    Do whatever it takes to avoid fooling yourself into believing that something is true when it is false, or that something is false when it is true.
    Demand specifications of the costumer.
    No problem to make it in any form or shape, even more possebilleties because of the strength and lightness of the used materiials, new forms impossible to build and work with the old construction will now be possible.
    I see some demand here ;)
    Master Navigator
    Interesting. Was the bridge assembled in one location (i.e., a factory) and then transported as one piece to its destination?
    Conch Master
    Mar 2011
    I think it is less boring if it was vertical and with an antenna on top!
    "Love Trumps Hate."
    Uh Huh, What Love?
    Orca Whisperer kf0rt's Avatar
    Denver 'burbs
    Quote Originally Posted by KC2KFC View Post
    Prototypes generally are.
    Build in sections combined them on the spot as far i could get any info on it.
    It mimics another half that is already there, that is why they picked that design.
    They can make any form or shape, and any length or wide you wish.
    Master Navigator
    Quote Originally Posted by KK4AMI View Post
    Or, build a second bridge, of the same size, and you'll have an indestructible half-wave dipole for the new WRC-12, 600 meter amateur band.
