Why not just built an inverted vee and use balanced feed line instead of coax. (You can even use TV old fashioned twin lead). Cut the vee for the lowest band you intend to use. Get the feed point up as high as you can and run the balanced line into your station. Then use a tuned (pref a link coupled type) between your transmitter (radios) and the antenna. You should be able to tune up on every band. I used this set up for years and it gave me excellent results. Mine was cut for 75 metres and it worked great on 75, 40, 20, 15 and 10. Nice thing is that if you build it right it is almost invisible. Most people would never notice it.
