Yep!!!!
Tip I just learned today...
Increase the level with Effect->Amplify.
You'll get a popup where you specify the amplification in dB. There's also a check box to "Allow Clipping". If you select a gain that will result in clipping, the OK button will be disabled unless you check "Allow Clipping."
