Results 1 to 10 of 16
Thread: The best way to learn CW?
    Forum Addict KA9MOT's Avatar
    Apr 2010
    Macomb, IL
    Any advice? I do have a block.....it is insane boredom. I don't know how to get over it. I've been seeing these cheap QRP kits and I think they would be allot of fun to build, are cheap and I'm betting they would be a blast to operate.... I just need to get over my CW boredom hump.
    I know I am a clown but I am very serious about this. Any advice? HELP!!! I've been trying to learn CW since I was a kid.
    Steve KA9MOT
    Macomb, IL
    Conch Master W5GA's Avatar
    When I was learning it as a kid, I would start reading street signs, billboards, anything at all to myself in code.
    Master Navigator KC9ECI's Avatar
    Wiscowsin
    G4FON. Take it in small chunks, 10 to 15 minutes a day. Took me about a year. When you get ready to try some on air stuff, check out FISTS (I didn't have much luck with them, but YMMV) or the Elmer program through the SKCC. Good luck.
    I learned it by sending code back and forth to a neighbor kid who was a ham. We used 100w 110vac bulbs keyed with an old navy key. We were lucky we didn't kill ourselves.
    Best thing I can suggest is to use one of the online cw tutors to learn the letters, numbers, and a few punctuation marks. Then, get on the air as much as you can. You'll be surprised how quickly your speed and accuracy improves. You might also want to do W1AW code practice, too. Pick out as much as you can. If it's plain text, you'll be able to fill in what you missed when you go back after you are finished copying. Hell, when you want to get on, let me know. I'll talk with you at any speed you are comfortable with. We can take as much time as you want/need.
    Using the website I linked to, it starts out with the easy "short" characters, like E I S H T M O.
    Use an "anagram server" to make words with these few characters. Run the Farnsworth settings so the character speed is reasonably fast (abut 13 wpm) but the overall speed is slow, 5-7 wpm. Later, when you speed up, learning the characters a little faster will help a lot.
    http://wordsmith.org/anagram/
    Anagrams for: E I S H T M O
    Try advanced options to fine-tune these anagram results.
    162 found. Displaying all:
    Homiest
    Eh Moist
    Eh Omits
    He Moist
    He Omits
    Hie Mots
    Hie Toms
    Hie Most
    Hies Mot
    Hies Tom
    Heist Om
    Home Sit
    Home Tis
    Home Its
    Homes Ti
    Homes It
    Hoe Smit
    Hoe Mist
    Those Mi
    Ethos Mi
    Hes Omit
    She Omit
    Mise Tho
    Mise Hot
    Semi Tho
    Semi Hot
    Smite Oh
    Smite Ho
    Times Oh
    Times Ho
    Items Oh
    Items Ho
    Mites Oh
    Mites Ho
    Emits Oh
    Emits Ho
    Mite Ohs
    Mite Hos
    Time Ohs
    Time Hos
    Item Ohs
    Item Hos
    Emit Ohs
    Emit Hos
    Ties Ohm
    Site Ohm
    Tie Mosh
    Tie Ohms
    Me Hoist
    Em Hoist
    Some Hit
    Tomes Hi
    Motes Hi
    Smote Hi
    Tome His
    Mote His
    Toes Him
    Toe Hims
    Toe Shim
    Eh I Mots
    Eh I Toms
    Eh I Most
    Eh Mi Sot
    Eh Ism To
    Eh Mis To
    Eh Is Mot
    Eh Is Tom
    Eh Sit Om
    Eh Tis Om
    Eh Its Om
    Eh Ti Oms
    Eh It Oms
    He I Mots
    He I Toms
    He I Most
    He Mi Sot
    He Ism To
    He Mis To
    He Is Mot
    He Is Tom
    He Sit Om
    He Tis Om
    He Its Om
    He Ti Oms
    He It Oms
    Hie Ms To
    Hem I Sot
    Hem Is To
    Hem Ti So
    Hem It So
    Hems I To
    Mesh I To
    Them I So
    Hes I Mot
    Hes I Tom
    Hes Mi To
    Hes Ti Om
    Hes It Om
    She I Mot
    She I Tom
    She Mi To
    She Ti Om
    She It Om
    The I Oms
    The Mi So
    The Is Om
    Me Hi Sot
    Me His To
    Me Hit So
    Me Oh Sit
    Me Oh Tis
    Me Oh Its
    Me Ho Sit
    Me Ho Tis
    Me Ho Its
    Me Ohs Ti
    Me Ohs It
    Me Hos Ti
    Me Hos It
    Me Shot I
    Me Host I
    Me Hots I
    Me Tho Is
    Me Hot Is
    Em Hi Sot
    Em His To
    Em Hit So
    Em Oh Sit
    Em Oh Tis
    Em Oh Its
    Em Ho Sit
    Em Ho Tis
    Em Ho Its
    Em Ohs Ti
    Em Ohs It
    Em Hos Ti
    Em Hos It
    Em Shot I
    Em Host I
    Em Hots I
    Em Tho Is
    Em Hot Is
    Ems Hi To
    Ems Oh Ti
    Ems Oh It
    Ems Ho Ti
    Ems Ho It
    Ems Tho I
    Ems Hot I
    Stem Oh I
    Stem Ho I
    Met Hi So
    Met Oh Is
    Met Ho Is
    Met Ohs I
    Met Hos I
    Set Hi Om
    Set Ohm I
    Set Oh Mi
    Set Ho Mi
    Eh I Ms To
    He I Ms To
    I first learned to send code and I would just tap out words, phrases, sentences, , names, etc. with my fingers or feet. I could send fast but I couldn't receive for nothing and thus could not get a license. Finally I decided to get the receiving down. I had an Atari 800 computer and I wrote a program to send code. It could be set to either generate random charachters and send them as code or, to read text from a file and send it as code. I could also set the speed, spacing, tone, timing, etc. That program helped me quite a bit and basically got me up to speed on the receiving. Then I just started listening to people sending on the air.
    Another thing that helped was to listen to code being sent faster than I was capable of receiving comfortably. I could do this by setting the program to send very fast or by listening to a fast CW op. on the air. Even if I could only pick out a letter here and there I would force myself to keep on listening. Then, when I would finally drop down to a slower speed it seemed easier each time.
    Now, I don;t know what happened to that program I wrote. It may be sitting on an old 5.25 inch floppy diskette somewhere in the back of a deep dark closet. But I am sure there are plenty of modern day resources available that work even better than my crude 1980's cw program..
    In any event those resources and techniques worked very well for me. Mileage may vary.
    Apr 2010
    Macomb, IL
    Thanks for all the good info. I guess if I really want to do this, I'm going to have to buckle down, stifle the yawns and get 'er done.
    Thanks again!
    Steve KA9MOT
    Macomb, IL
    Ever listen to the W1AW broadcasts? They send pages from QST.
    I have always sent faster and better than I receive. Imagine that.
    I think that's pretty much the case for everybody. I can send pretty decent code at about 20 WPM but I can't copy it worth shit even at 5 WPM.
