Results 1 to 10 of 23
Thread: Crickets !!
    Crickets !!
    Well, it's almost December and I am still running the air conditioner and fans, I am still hearing an occasional cricket chirping and, i am still getting occaisional mosquito bites outdoors. And yet over a month ago we had an October snow storm. Talk about psychotic schizo weather !!
    The chirps are in your head?
    I hear that shit all the time.
    Jiminy?
    This building is kept too warm. About 72-73 degrees F which I consider to be uncomfortably warm for indoors. I prefer the temps around 62-66 indoors. Normally at this time of year I keep a window open and that is enough to keep the temp down to a comfortable level. But since it's been so unseasonably warm I've had to throw on the air conditioner.which I have set to 66 degrees. earlier I was taking a rest and the Ac kicked on, cooled the room down and was taking it's sweet time to shut back off. I woke and it was freezing. I had to shut it manually. Looks like I'll probably be using the AC till about Wednesday. It's going to be quite warm till Wednesday and then more seasonably cool for a few days.
    September oktober, november too warm and dry for what it should be.
    looking at 12 C in the daytime when it should be 3 or 4 C, 7 mm rain over this month 80 mm normal...
    Flowers started to bloom again, leaves just dropped off the trees 2 months late, and it'll stay like this at least another 14 days.
    National Park N.J.
    Try to hang in there. Ok?
    We had snow on the ground this time last year. Now, temps are hovering around 50F with a predicted cooling trend towards the end of the week. If it doesn't snow much (or at all) this year, not a single tear will be shed.
    National Park N.J.
    You got that right, I'm still using the bike for work. The ride in is a bit nippy, but the ride home is great. Hope it lasts.
    Too much rain forecast here for a motorcycle commute early this week, George - but I'll get at least one day later on to ride in. Since temps will be in the high 20s I'm going to need the heated clothing.
    On the pedal-bike front, I got 75 miles in between T-Day and Black Friday. Could have gone Saturday too (temps in the mid 60s) but needed to do some maintenance work on the bikes.
