Tha'ts what we said a long time ago when I was working in a supermarket. They told us to go sweep out the bathroom downstairs in the basement. I walk in there and a split second later I walk out... There was actual shit on the floor out of the toilet !! As I walked away I said, "this is a job for the manager".
ok
Those aren't your everyday household TP rolls which if I remember correctly are only about 65 feet per roll. The rolls you linked to are extra large commercial rolls which are 1000 feet per roll or 6000 feet per case which is equal to about 92 normal household rolls for only $32. So It's actually much cheaper then most of the stuff people buy for home use. In fact that's the same stuff we used at the restaurant and the Granite shop. They go in a big ugly tamper proof dispenser.
Problem with those big rolls is the didn't do a tensile-strength vs. angular momemtum analysis. EVERY ONE I've used had the problem that you had to unwind the TP by rolling the roll...just pulling just pulled off a sheet or two. OTOH, it IS nice to be assured of the proper equipment to finish the job!
It's a cost saving measure...
Complete the cycle by using just one sheet. Fold the sheet into 1/4's, and tear off the folded corner. Use the sheet with your middle finger through the hole created. Use the torn off corner to clean under your finger nail.
This would be the corporate approved method.
The wrapper says it's made for big assholes.
As a public service, a lifetime supply has been provided to congress.
