Results 1 to 5 of 5
Thread: Why does it work on a bread board, but not a proto-board?
    Ok, so this weekend, I spent the better part of working on a project that should have taken like 30 minutes.
    It's a simple soundcard interface. Works fine on a breadboard, but when transferred to a protoboard, the rig stays keyed no matter what?
    Basically, the DTR is connected to the base of a NPN transistor, with the collector wired to ground, and emitter wired to the PTT pin. Works FB on the breadboard, but when moved to a protoboard, and soldered, it keeps the rig keyed.
    I've flipped the E-C connections around, same thing?
    My serial port is -12V low, and 10V high. Any thoughts?
    Did the transistor short out after installation or testing?
    When weird things happen, I check the premise of my "grounds".
    Spooky stuff can occur if there is a potential between them.
    Good advice. I pulled apart one of the last interfaces I built, and it appears I placed a blocking diode from ground to collector (As well as ground to most of the connections)...
    Seem there was a reason for it... hehe. I've got to start a notebook on this stuff. My memories aren't what they used to be.
    Because boards do not work on bread alone?
    Cutch 300!!!!!
    Quando Omni Flunkus Moritati
    One thing to keep in mind regarding breadboards, especially at radio frequencies:
    Inter-terminal capacitances - them'll git ya.
    Effective capacitance between sections of the boards I've used has been on the order of 10-15pF. Trivial at audio frequencies; most assuredly not at, say, 20MHz and up.
