Results 1 to 10 of 33
Thread: question from reader
    SK Member (02/27/2012) W5RB's Avatar
    Apr 2010
    Ruisseau de Merde
    It'll burn with the same brightness. The difference is that since the electrons in AC don't actually go anywhere , and only move back and forth , and thus are not used up , AC is 100% efficient .
    I won't question your Creator's wisdom , but you are responsible for your own actions .
    Russ, W5RB
    Quote Originally Posted by W5RB View Post
    this seems to conflict with rms or is that just in a resistor producing heat?
    shouldn't the dc produce more heat/light?
    National Park N.J.
    I use DC to power the filaments in several radios, I don't think the tubes even noticed.
