A reader asks:
Will a 12 volt automotive incandescent dash light bulb give off as much light if it's powered with 12 v ac (60 hz) as opposed to 12 v dc?
...and if there's a difference, how much?
A reader asks:
hint:
rms
It'll burn with the same brightness. The difference is that since the electrons in AC don't actually go anywhere , and only move back and forth , and thus are not used up , AC is 100% efficient .
I won't question your Creator's wisdom , but you are responsible for your own actions .
Russ, W5RB
Q2)
Would the same bulb produce equal light on the 12 v ac voltage as opposed to rectified 12 v?
I use DC to power the filaments in several radios, I don't think the tubes even noticed.
Nice avatar George.
The neocons seem to be getting genuinely agitated with this demonstration stuff. Let's hope it spreads.
This is how real change will be affected. Not that voting shell game crap.
No. While staying at a Howard Johnsons, I saw a documentary where a princess said Obi Wan Kenobi was the last hope.
The bulb will dissipate the same amount of power in both cases, so if light output were solely dependent on that, the brightness would be the same.
However, the brightness, i.e. amount of visible light emitted is a highly nonlinear function of filament temperature, which in turn depends on filament current in a nonlinear fashion.
It's not inconceivable that the increased light output at ac peaks could offset the reduced light output at zero crossings. In any case, I'd expect the difference to be small.
