How would I go about amplifying the AC current reading that I'm picking up from the outside of a spark plug wire. I'm building a tachometer.
I've considered a transformer then adding a rheostat for calibration.
I should add, it's 1 cylinder.
Yes, and one would need to step up and condition the voltage - rather than the current - to get a usable reference. Something like a JFET would work nicely without excessively loading the pickup coil and reducing its output. For TTL gating purposes you're aiming for 4.5-5.2v on peaks.
Add turns to your pickup inductor.
Assuming you're not using a sealed unit. Some of the setups built for the auto-repair community cannot be disassembled for modification. I have an old Sears diagnostics meter that includes a tach function and most of my motorcycle ignition systems don't generate enough high voltage to get an accurate reading. I had to go to a "Daytona" brand accessory digital tach (which triggers off the coil primary; switched 12v) in order to get a usable low-RPM reading for purposes of carb synching, idle-mixture settings and so forth. Frustrating, as the Sears unit's pickup merely clamps around the #1 plug wire...and I had to add a pigtail to the ignition circuits of each bike where the Daytona will be used.
Ah, I'm using coiled wire. Insulated probe wire.
Just pull back the spark plug boot and connect a lead directly to the terminal of the plug wire. That should give you plenty of voltage...
