Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: TS-430
    Conch Master W2NAP's Avatar
    Mar 2008
    W2NAP
    TS-430
    Well I finally got a dipole up in the room here yesterday. just did a short QSO with someone 12 miles away S5 (not bad IMO since the dipole is inside) sadly when i key up my wifi card shuts totally off :(
    and the 430 is going to have to be re-aligned. readout showed 28.305 but was at 28.304.85. also fan on the heatsink didnt come on in x-mit (got to read a bit more on that not sure if is should or only dose when warm)
    good note. stock mic, wonderful audio got to love these old kenwoods
    Conch Master W5GA's Avatar
    Quote Originally Posted by W2IBC View Post
    Gotta love those digital readouts. How did we ever survive when our frequency readout was a series of nominally 1 Kc. hashmarks between 2 larger numbers?
    Quote Originally Posted by W5GA View Post
    And rigs drifted so much over the course of a long rag chew that it was never much more than a rough estimate to begin with! ;)
    Crystal markers worked, but digital is better.
    I wonder about that when we obsess over .15 Khz.
    and the 430 is going to have to be re-aligned. readout showed 28.305 but was at 28.304.85. ...
    5.3 ppm offset! Not too awfully bad I guess. TCXO timebases could be worse.
    Mar 2008
    W2NAP
    is not bad per say. wouldnt mind getting it better tho.
    Is the display an actual frequency counter? What process did you do to find out that this unit was 5.3 ppm off frequency? What is the frequency reference?
    Mar 2008
    W2NAP
    guy up the road has a 718 thats where he said i was actually at. meh
    anyway, i still have to check it out make sure everything is really up to par. i noticed a few off things about it. when AM mode is selected 1 of 2 things happen 1. display goes out no RX at all, or 2 display stays but all you will get is noise.
    In previous lives, I have designed precision reference oscillators. I have kicked around the idea of designing my own hammy style oven oscillator for commercial use. The company i work for now has a new crystal design that would be kick ass for a fairly low power crystal oven oscillator. But I have no idea if the market would have that kind of demand to make it worth my while.
    Whuddya think? Right now, you or your buddy are probably off by a total of 5.3 ppm more or less. I could probably get that down to better than 0.1 ppm from -20C to +55C for 10 years.
