Results 1 to 10 of 11
Thread: Something out of nothing
    Well, almost nothing. I wanted to take part in a club net on a 70cm repeater but the only rig I have for that band is a VX-2 HT, which only puts out 375mW. I couldn't hit the repeater from my QTH using the whip antenna but I don't have much money to spend on ham gear these days so I hunted around to find something I could build with what I had on hand. The result is this oddball combo of a quad and a yagi, called a Quagi, which I built with about 10 feet of #14 copper wire, a 4-foot hardwood dowel and some duct tape. Damned if the thing doesn't work!
    HELL YEAH BRO! FBOM hihi
    RR.
    Went up on a hill back of the place and managed to hit a repeater on Palomar Mountain, about fifty miles north. Not bad for a bit over one-third of a watt.
    Conch Master W5GA's Avatar
    Good job!
    'Tis all about gain, and it's easy to get with shorter wavelengths.
    Oh, and FB OM HI HI.
    RIGHT ON!!!!
    I don't buy antennas, unless they are for mobiling (It's easier to buy the whip + ferrule as one piece). For home use: Homebrew all the way :)
    Grand Exalted Poobah WV6Z's Avatar
    Sep 2007
    Oh no, I'm still on that feckin' island!
    Pure awesomeness!!!
    KD8EFQ ~ "With MFJ one might as well stand outside during the worst possible calamity and wair for death."
    Necessity being the mother(fscker) of invention, I've thrown together more than a few contraptions like that over the years. Yours is the first I've seen with a loop as driven and reflector elements; most use one for the reflector only.
    Nice work!
    Sep 2007
    I have a beautiful PVC and welding rod cubical quad that Charles and Brad picked up for me in Charlotte I think it was, it worked awesomely well with my VX2R too...... I do well with wire....... hidden in the trees, than I do with anything else. Charles and I did some dual band copper tubing j-poles once...... as I recall we ended up with like 2 that worked out of 5 and the 3 that didn't work were a total FAIL........ they didn't work ANYWHERE and for no apparent reason.
    I started a fad with a bunch of newbies by suspending a twin lead j-pole up in a tree.
    Some of 'em bought SWR meters, antenna analyzers (for those who had the money), soldering irons, twin lead, coax, and the PL-259 plugs. A lot was learned, but we had a few frustrated dropouts who had their buddies build them. We built dipoles and "coat hanger" verticals too. I politely refused to build any, and deflected by insisting on the learning experience.
    Later, I stuffed that twin lead J-pole in a PVC pipe for mast mounting.
