The FAA now allows the airlines to limit what sort of electronic devices are allowed to be used, their call.
Anything that transmits should be a given, yet people insist that a wireless headset has no transmitter.
Another problem is that the Empower system provides 15VDC, enough to power, but not charge, most laptops.
So people go out and buy inverters and run the AC adaptor/charger.
Due to the reduced density of the air in the aircraft the batteries will run hotter than normal and are more susceptible to failure.
Fire in an aircraft cabin is not a nice thing to have.
Even the Apple laptops, they run on a 24 volt adaptor, will operate, but not charge, on 15 volts.
PS, I started on this while doing research on Hospital Safe laptops, units that will not get warm enough to injure if placed on someone or charge the battery when not safe to do so.
With that said, here is the link to the Apple provided information on the iBook.
http://developer.apple.com/legacy/ma...G4/iBookG4.pdf
