Results 1 to 10 of 14
Thread: Kewel Article
    Master Navigator kd8dey's Avatar
    Kewel Article
    http://www.riccibitti.com/pcb/pcb.htm
    Now if I only had a laser printer and can find something cheap to do the artwork (to scale) with
    Honorary Old Fart
    Dirty Old Mans club Junior Auxillary
    (Dirty Old Man in waiting)
    Get off My Lawn.
    4 out of 5 Seniors Prefer the taste
    of Alpo over other leading National Brands
    I bought a brand new Brother laser printer for $59. How much ham gear can you buy for that little?
    Slick PCB-making technique, though---I bookmarked the page.
    Hey, did you see this on the same guy's site?
    http://www.riccibitti.com/nut_home.htm
    Looks like a very cool option for simple stuff when you don't need the power of a full-blown PIC or Amtel AVR microcontroller.
    Neet Technique.
    I bought one of those Radio Shack etching kits back in the day. I flipped the design and surface mounted through hole components. That was 1980. I was a bit ahead of the times. lulz.
    These days I buy those premade pegboard looking boards that they sell in various sizes. Of note, the also sell round ones. Is that cool or what!
    Neet Technique.
    Of course, that was back when your eyesight was still good enough that you could have seen SMDs, if they had existed at the time.
    I had a subscription to Science 80 magazine at the time. Some company was in a write up about miniature caps made from magnesium plus composites. In my case, I would have preferred to have a drill press to drill a bazillion holes.
    May 2008
    What does it do that a Basic Stamp does not do?
    http://www.parallax.com/Store/Microc...3/Default.aspx
    Remember to pit apples to apples, the BS1 chip has everything on board, right down to the voltage regulator.
    And what is the cost per unit? all things being equal.
    Uh, nothing? They are less capable than a Basic Stamp but they are cheaper for embedded purposes and easier to program.
    May 2008
    Cheap?
    http://www.nerdkits.com/store/
    The chips themselves are $6/7, depending on the one you pick.
    And it is on a par with the basic stamp in function, just not as complete or compact.
    I said cheaper than a Basic Stamp.
    http://www.jameco.com/webapp/wcs/sto...de=WSF&CID=GMC
    And that does not address the programming issue. A PIC or AVR must be programmed using ANSI C. The Nut Chip uses a much simpler, although less capable, truth table method of programming. If you don't need the full power of a PIC, AVR or Basic Stamp or don't know C, the Nut Chip seems like a good alternative for hobbyists.
