You make the call
One of our rental vehicles , an 06 Ford F-150 pick up with a V-6 , came back from long term rental running really bad, with a check engine light on. I scanned the truck and found 3 codes. Multiple cylinder misfires, MAP sensor, and an o2 sensor. Replacing the sensors eliminated the codes, but the engine was still running badly. Removing each plug wire while the engine was running, I located 2 dead cylinders. I then took a compression test of each cylinder, both were 0. I then pulled the valve covers and checked the valve gear for both cylinders. Rockers, push rods, valve springs all looked good. I am fairly certain that now I understand what's going on here. The three questions I have for you backyard mechanics are......
A- What is wrong with this engine?
B- What needs to be done to repair it?
C- Why did it happen?
Sorry Luke, you have to sit this one out.![]()
