I've got Echolink installed on my iPhone now, and popped into the W2VL node.
It works, but nobody said...
Hello?
Hello?
only machine i have used here local is the 145.39 machine...
most of the time i keep the little HT locked on 146.58. I do listen to the 442.65 machine down in indianapolis alot.
Seems like the local repeaters are a bit more active this week. Could be things were slow over the holidays. repeaters can be somewhat cliquish... much like 75 meters can be quite cliquish. But there are a couple nice repeaters around here which I do hear some interesting conversations.
Hmmmmm... I'm wondering if this is also the same guy who ran a VHF machine in Manhattan that had very good coverage throughout the borough ? I could work it from down in the subways and from the lower track level in GCT. I was never confronted while using it but, I could never figure out if it was a truly open repeater either. He was also very reluctant to give out any info on membership, etc. In any event my use of his machine was limited as I preferred to work the Carmel "5130" machine from my HT with my AEA "Hot Rod" antenna from the sidewalks of Manhattan. Or, my friends "simplex repeater" in Yonkers. yes, i said SIMPLEX. It would record up to 3 minutes of your transmission and when you unkeyed it would retransmit your message just as you said it. A few of the people at work and the lady in my avatar found it amusing.
sadly, they don't make the "Hot Rod" antenna anymore.
In the NYC/Catskills region, KQ2H is a friendly and easy to get to repeater. One thing is...you need the tone on transmit, but not on receive -- took me a while to figure how to set up my TR-F6A to do that. I've met a number of good people on that machine, and the 10m input sometimes provides DX. There are also other machines it's linked to.
