Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Thanks Carl The BeeSO
    Just made a transcontinental contact with Carl, KJ6BSO on 20m, 14.287 between 23:30z and 23:40z. Propagation was fair, copy was a 4, no band noise, signal was S3 to S6.
    Well, all reet, Charles, it was fun. Sounds like you have a much better antenna than I do because I could barely pull you out of the mud about half the time. My station is about as basic as it gets and I really need to improve my antenna systems if I ever want to get serious about this ham radio thing.
    All I was running was a basic barefoot set up. The Heil GM5 in battle mode helped I guess and I heard you clearly. We have very high iron content in our soil. Might as well call it rust.
    Good ground conductivity is nice. I know my station RF ground leaves something to be desired, I'm hooked to a cold water pipe though an eight foot length of 4/0 stranded copper (the largest they had at Home Depot) but my connection point is a good ten feet away from where the pipe goes underground. I'd drive a ground rod but my shack is surrounded by a poured concrete walkway and the soil here, while not filled with iron the way yours is, might as well be made of it, it's so hard. Takes a pick and a digging bar to plant a small shrub. But, on the positive side, it's apparently got a lot of aluminum in it so it's above average in conductivity.
    Use cattle salt, comes in large lumps of rock like salt, dig a hole around your earthrod, fill with that salt.
    Will take a year or longer to dissolve depending of the rainfall, and moisture.
    Some catlitter fillers containing bentonite can be used as well.
    Works for me, and spreading roadsalt in the winter helps too ;)
    Cor, check out my Flickr site. You'll see that I have no trouble obtaining salt.
    Looks delicious!
    That was cool Carl, enjoyed the tour.
    Quote Originally Posted by ki4itv View Post
    Thanks, glad you enjoyed it. There are several others there if you're interested:
    http://www.flickr.com/photos/22279637@N06/sets/
    That's crazy... Just the thought of that much salt... I thought crunching through a thin layer in dried lake beds was a lot...
