So, this is a multi-pronged question I pose to all the knowledgeable folks here (And, maybe not even knowledgeable, but idea people too):
I am looking to do a solar powered, Single-Board Computer, with audio out to a low-powered 2 meter transmitter, which is managed via wifi (ie, uploading new audio, forcing a reboot, etc).
The only purpose for this SBC, is to run a small webserver for admin (PHP enabled); and output an audio file to it's audio out. Must be as low-power consuming as possible, and hopefully, inexpensive.
The transmitter, maybe 2 mW. Maybe even a watt, if power loading is minimal (This is a solar powered system, after all).
So, firstly, I'm looking for some sort of Single-Board computer, even if it's a MicroController, which I can bend to my will enough run a minimal webserver, and output audio. The webserver really isn't a requirement per se; but some sort of remote upload of the file via wifi. Any ideas? Can this be done with an Arduino, or BASIC Stamp? Or even a Spin board?
Now, onto the transmitter: I have a Scosche FM transmitter. The kind you get for a car, so you can play your iPod or whatever through your stereo. It's a FMT4R. It looks like much of the xmit circuit can be "bent" to pull it up into the ham bands. I can swap inductors and the like out. Do you guys think it's possible to mod this device enough to get it into the simplex portion of the 2 meter band? If not, are there any plans for a QRP 2 meter transmitter out there?
And, lastly, can all of this be powered via a 5-10W solar panel, coupled with rechargeables? If so, is there is project out there on the web to keep a bank worth of batteries floated with a solar panel, so the kit is powered from the batteries when no sun is out there, and the sun recharging + powering the kit when there is enough sun? Now, for this part, I'm not expecting miracles, and I'll assume I'll need to swap fresh batteries in there from time to time. Looking really to "extend" the battery life, to reduce the number of trips to change batteries out.
This project got it's roots with the WikiTX project, as a manner of proving out the concept (A self-sustained, community radio site). I figured this can be done on the ham bands, as long as I restrict access to hams, and keep content focused for hams.
