Results 1 to 9 of 9
Thread: Change al-811H to 240V
    Beach Bum
    Oct 2008
    DONALSONVILLE, GEORGIA USA
    Well I am kind of confused about how to change my amp to 240V. The manual is kind of confusing to me.
    The AL-811HX (export model) is wired for 240V, 50/60 Hz
    operation. The appropriate plug is not provided for this model.
    You must wire the proper plug on the end of the power cord
    supplied. Simply cut the existing plug off and wire the
    appropriate plug in its place. If the line voltage in your country
    is not 240V, then you must change the transformer to the
    appropriate setting indicated by the chart below. Note: the AL-
    811H transformer allows operation on 100V line voltage in
    countries such as Japan.
    NEVER REWIRE THE POWER SUPPLY TO BOOST THE
    HIGH VOLTAGE ABOVE 1800 VOLTS. ALSO, DO NOT
    ATTEMPT TO REWIRE THIS AMPLIFIER WHILE IT IS
    CONNECTED TO POWER.
    The wiring between the fuse box and the amplifier AC outlet
    must be 14 gauge or larger in order to supply the operating
    current required (10 amperes) without a significant drop in the
    line voltage. The outlet should be fused for the wire gauge used.
    VOLTAGE BUCK BOOST PRIMARY
    *120 A to 1, B TO 2 C to D, E to F
    110 1 to 2, (A,B OPEN) C to D, E to F
    100 A to 2, B to 1 C to D, E to F
    For 240, 230, 220 all three primary conditions apply ↓
    **240 A to 1, B to 2 no connection C to D
    230 1 to 2, (A,B OPEN) D to E
    220 A to 2, B to 1 no connection E to F
    Now it looks to me like I have to cut "CtoD" jumper but the start of the instructions say "Simply cut the 120V plug off and wire on a 240V plug" so which is the proper way to change it? I don't want to "Let the SMOKE OUT". There is a sort of diagram that will not copy and paste for strange reason.
    73's
    Bill W4BD
    Donalsonville, Ga.
    EX W4BPK
    SPAR # 529
    Member ARRL
    IF IT'S POLITICALLY CORRECT THEN IT'S A LIE
    THE ONLY GOOD GUN CONTROL IS HITTING WHAT YOU ARE AIMING AT
    I DO EQSL OR DIRECT OR NO QSL DUE TO THE FACT THAT I CHASE NO AWARDS
    You most likely have to do both. Because the transformer is stepping up 120 to whatever it needs. By wiring just the plug, and not the transformer, you would double all voltages after the power supply circuits, and let out the smoke.
    Caveat being, I've never done this operation before for this piece of equipment, however, it would follow, as I've seen similar instructions for other rigs.
    DO NOT ATTEMPT TO REWIRE THIS AMPLIFIER WHILE IT IS CONNECTED TO POWER.
    "Okay, important safety tip. Thanks, Egon."
    Beach Bum
    Oct 2008
    Carl
    Well I am crazy as hell but I ain't STUPID. I guess there are fools out there that would try to change it over with out unplugging it.
    I am still reading the reflections you sent me.
    73's
    Bill W4BD
    Donalsonville, Ga.
    EX W4BPK
    SPAR # 529
    Member ARRL
    Quote Originally Posted by W4BD View Post
    Sadly, you are probably correct.
    Not exactly gripping reading, eh? But very educational. I probably should read it again myself.
    May 2008
    On an Island of Islands, EL09sl
    Hello.
    Read that again.
    First, you cut off the plug if it is not the correct one for your country.
    Second, if the voltage is not 220,,,do the transformer tap changes.
    This is a 1, and perhaps 2 step change.
    Beach Bum
    Oct 2008
    Well I got the time this morning to change the 811H over to 240V. I measured the voltage and I have 246V no load on the outlet. I unplugged the amp so I wouldn't let the SMOKE out of ME and wired the 240 plug white and black are the 2 hot leads and green is ground. I pulled the cover off the back and cut the wire from C to D and put cover back on. While I was at it I wired in another 240 receptacle so I can plug 2 amps in at the same time but only run 1. Plugged the 811H in and turned it on in Standby and after about 1-2 seconds it blew both fuses in the AMP. Anybody got any ideas as to where the problem can be. The directions are about as clear as mud on changing the voltage at least to me. I will get a couple more fuses and see if anybody can point me in the right direction.
    73's
    Bill W4BD
    Donalsonville, Ga.
    EX W4BPK
    SPAR # 529
    Member ARRL
    http://www.nojolt.com/Understanding_...circuits.shtml
    May or may not help. If you've wired the outlet correctly, double check your amp wiring and check the fuse ratings.
    Please don't take my word for this as I am no expert on the amp.
    Beach Bum
    Oct 2008
    Well if you look real close at the text it shows a tiny little arrow pointing down and the statement "ALL THREE PRIMARY CONDITIONS APPLY". For 240, 230, 220 all three primary conditions apply ↓
    220 A to 2, B to 1 no connection E to F. I went in and I had already cut C to D and I added D to E and cut E to F. Put new fuses in and plugged it in and turned it on and I have 1800V HV now where I had 1750 or so. I was getting about a 10:1 amp factor or 10W drive and 100W out and the light would kind of dim when I would key the amp so I will play around later on tonight and see if I still get dimming of the lights.
    73's
    Bill W4BD
    Donalsonville, Ga.
    EX W4BPK
    SPAR # 529
    Member ARRL
