Results 1 to 10 of 27
Thread: overkill railroad bridge
    Made for extra heavy loads?, overkill indeed.......
    It has to be heavy duty. The Teaparty train will be going over it, and it's packed.
    Ellicott City, Maryland, USA
    I suspect the angle at which the photo was taken and the telephoto effect (evident in the reduced foreshortening) make the mass of the span seem greater in the image than it perhaps is in reality. It is the height of the trusses that captivates me. It appears to be a single-track bridge given the shape of the entry portal at the truss; that central span must be a hell of a lot longer than it appears at the angle of the image. Too bad the trees hide the area under the span over the river -- the presence or absence of piers might give some hint of the length.
    A quick bit of research indicates the bridge was built in 1916 and consists of two continuous spans, each of 775 feet, which explains the height. The angle of the image, as I suspected, is key to making it look so odd. It was, and is, considered an engineering marvel.
    73 de Albi
    Veritas vos liberabit!
    Thanks for supplying extra info Albi.
    It sure does explain things a lot better.
    I think it still is a marvel, getting older lets one appreciate old things more i guess ;)
    And my father in law had for 25 years a restaurant in the train station here in Sneek does help.
    He still lives there with his wife in the top section.
    This steamtrain will ride in the summer for a few weekends for tourists.
    That locomotive looks German, Cor. Was it built at home in Holland? Germany was still full of them when I was there in the 1960s. All painted black and red, and most having that curious extension of the piston rod thrusting from the front of the cylinders. Looks to be a consolidation (oOOOO), but hard to tell at that angle.
    No other machine in history, save perhaps the loom, looks so much alive as a steam locomotive.
    73 de Albi
    It is a German steam locomotive, buildt in 1963, then exported to the Netherlands, completly overhauled.
    Wagons, inccluding luxurious dining wagon, a Kof ranging loc etc all are as new and frequently used in the summer.
    In the restaurant my father in law had till his pension is now the railway museum.
    250 volunteers maintain the steamloc, and all other equipment and run the show, my wife is the secretary for the board.
    Senile Member WA4TM's Avatar
    Here is a screen capture of the bridge from Google maps street view...
    Click image for larger view..
    Quote Originally Posted by WA4TM View Post
    As I suspected, very long spans for a riveted iron-truss bridge dating from 1916. A long string of loaded coal hoppers puts a substantial pull on that truss.
    73 de Albi
