Results 1 to 10 of 15
Thread: VMware can help in protecting your computer from intruders
    Orca Whisperer N1LAF's Avatar
    Ledyard, CT
    I am running XP Pro, which works fine with me, but I also set up a Virtual Machine with XP also. In this VM window, I installed all the different browsers to make comparisons and testing of web pages - how they are seen on the different browsers.
    I also use this VM window to test third party software, and general web browsing. If I did hit something abnormal or suspicious, no problem, would just copy the VM window folder/files over itself and cleans from the problem.
    My VM disk is 10.26 GB, small enough to store on my USB drive as well.
    Think of the VM window as a containment field. It is a barrier between your base computer setup and the Virtual computer setup. The disk in VMware is a virtual disk, and shows up in the base computer as a file. As far as I know, and others, please speak up if I got this wrong, that any malicious software running in a virtual machine will not affect the base computer system.
    VMware player is a free download. (requires a free registration to download)
    To set up your containment system:
    1. Download and install VMware player.
    2. Create 'New Virtual Machine' and install your OS into it.
    3. Install Firefox 9or/and other browser software. You can also install AVG anti virus software
    4. Do all your browser customizations.
    5. Copy the VM folder to another location, this will be your baseline and restore point
    If there is a virus or malware lurking in your VM window, then close VMware, delete the folder, and copy the baseline where the folder used to reside. Start again.
    This method will save you lots of hassles. A must to try out third party software. It is also the easiest way to break into Linux - I have Ubuntu 10.04 in a VM window. You can use VMware for windows 95/98/NT/2K/XP/Win7 as well.
    Use DOSBOX for Windows 3.1. Believe it or not, there was a need to run Windows 3.1 to run some legacy software to extract data (engineering thing), and DOSBOX does this well, where it is problematic and not supported with VMware.
    In using VMware, make sure you download the tools/utilities for each OS system. This will allow the screen resolution to change on the fly as you re-size the VMware window.
    There are plenty of resources here on the Island that can help you with questions.
    VMware Player Download Link: http://www.vmware.com/products/player/
    Ledyard, CT
    Screen shot...
    Attachment 3267
    Ledyard, CT
    Browsers..
    .Attachment 3268
    Even better: Don't use Windows, at least not in an Internet-connected machine.
    Ledyard, CT
    Using DOSBOX for Win 3.1
    Attachment 3269
    Ledyard, CT
    Ubuntu!
    Attachment 3270
    Administrator ad4mg's Avatar
    VirtualBox allows you to take "snapshots" at any time of the machine state at that instant. In case of a problem, you simply revert back to one of these snapshots. I wonder if VMware has a similar feature. I'm not near the machine I installed VMware on.
    Any issues running Win 3.10 in DosBox such as sound or video? I have no real reason to try this, but it seems interesting. I have a copy of Windows 3.11 for workgroups.
    Ledyard, CT
    For Win311 on DOSBOX, what you need is found here:
    http://vogons.zetafleet.com/viewtopic.php?t=9405
    There they describe how to install video and sound drivers.
    By default, DOSBOX emulates S3 graphics cards. Drivers for that and the Tseng3000/4000 as well
    Paradise graphic card drivers, and will natively support SVGA drivers
    Joystick drivers
    Soundblaster is supported, and have drivers for this also
    Win32s (remember this?) is also supported
    A site with downloads, tips and tricks to Windows 3.1x: http://www.win31.de/eindex.htm
    Full setup description for all these components are found at the website: http://vogons.zetafleet.com/viewtopic.php?t=9405
    Jan 2008
    DM79ms
    I have a simple question..
    Why?
    I get why a Linux user might want/need a Windows guest and vice versa, but under what rare circumstances would you need Windows 98 thru Windows 7, and DOS for god sakes? :)
    In order to watch TV in my office, I have to use SlingBox (no TV coax in the office), and that's a Windows/Mac only app, so I use Windows XP guest in VirtualBox for that. Heck, even our accounting software runs natively in Linux now.
    Ledyard, CT
    Quote Originally Posted by W4GPL View Post
    Why?
    Because we have clients that still run Win2K, and in developing software, good to see programs are compatible with the different operating systems. I have a few programs that will not run on OS's later than Win98. Setup is easy to do with VMware, and it is neat to do these things. Last week, a friend asked me if I had a copy of Win3.1 because of a program that would not run after win3.1, and needed to extract/recover data. So I did it - everyone is happy. Windows 7 has some compatibility problems, and VMware 'fixes' that by running XP and/or 2K. Now it is also a 'firewall' in trying different software without crashing the base operating system. You can see some advantages in this.
