Results 1 to 3 of 3
Thread: 12V DC Regulator
    12V DC Regulator
    I'm looking to build a 12VDC, 2A minimum regulator for my car.
    I know, first question is: Why?
    Well, two-fold:
    * I'd like to keep a constant voltage of 12V (Not 13.8VDC nominal) to my handy radio, which will serve as a data radio for the car. It needs 12VDC (According to the manual), but appears to run fine on 13.8VDC(From my base station power supply). I'm trying to be safe here.
    * I would like for the radio to turn off is vehicle power drops below 11VDC (Safe start voltage). This is secondary, I know I can just turn off the radio. It's for those "Oops, I forgot" times.
    Anywhere I should start looking for template circuits here, and build instructions? First time in higher-power applications (couple hundred milliamps has been my experience, and that's in signaling), so it's kind of, new ground for me.
    Double check the input circuit for 12 volts on that radio, it may be regulated already.
    Here's a "cookbook" of sorts, IC regulators are cheap.
    http://www.teachers.ash.org.au/jfull...regulators.htm
    LM350 is a good choice, 3A max.
    http://www.national.com/mpf/LM/LM350.html#Overview
    Suggested RadioSnack semiconductor part numbers... will work up to 1.5A, just heatsink the snot out of it?
    Do you really need 2A? Measure it.
    http://www.radioshack.com/product/in...ductId=2062601
    Using the LM317 above because the "Snack" is everywhere. They also have a 2N3055 power transistor that is a 30A overkill, but a popular combo. RS available TIP42G might work as well as some others they have.
    The LM350 is a nice simple solution.
    Thanks :) Bookmarked for great justice!
