One key thing I've learned about antenna's over the past month: There are priorities for location you must follow:
* Height
* Proximity to metal
* Indoors vs outdoors
I found this out by tinkering with "Better Locations" for my 20 meter dipole. First arrangement went like this:
Code:
                     | <--Window
                     |    ^Feedpoint        ****   <-- Tree
This was located in my attic. It did, ok. Could never get the SWR under 2.1:1 however.
Next one:
Code:
                                               >| <-- Window with cable coming in
This was located all in my attic. It actually worked really well, got some RFI in the shack (I could heard my PSK signal over the computer speakers). I got a half-contact (I called CQ, someone came back, but then someone else fired a PSK signal on top of us). SWR was 1.2-1.5:1 on the entire 20M band!
So, genius that I am thought,"You know, if I can get this all outdoors, I'd loose my RFI, and get less noise being away from the house! Sure, It'd loose about 6 feet, but it should be fine!"
So, on my railing for my upstairs porch, I installed extenders to get the antenna about 1.5ft from the metal railing, and out from under the corrugated steel porch roof. Dipole fully stretched out on both sides, I should be golden, right? Nope.
Same antenna, could not get an SWR under 3.1:1.
Antenna is going back into the attic until I get a roofing ladder :(
On the bright side, since I like using my rotary tool, I made some pretty decent center insulators out of pill bottles, and figured out how to make a killing with the CB folk: Take pill bottle, make antenna. Drop 2-4 Motrins into the bottle, and seal with hot glue. Sell antennas for $100-$400 (Depending on how many pills), and market them as 1,2,3, or 4 Pill antennas! And call the hot glue filling "Swer Lube"
