Results 1 to 10 of 12
Thread: Need nut, bolt, washer specs for Rohn 25 tower
    SK Member (Late April, 2019) W4RLR's Avatar
    Dec 2009
    Sewanee, Tennessee EM75cc
    I'm going to try and get the tower up in the next few weeks. Does anyone know the sizes and grade specs for the nuts, bolts, and washers to put the thing together. I have the tower sections, but none of the hardware.
    Any help would be appreciated. I thank you for your support.
    73 de Richard W4RLR
    Southern born,
    Southern bred, centrist conservative.
    Posting messages via HughesNet satellite internet.
    Retired U.S. Air Force NCO
    Member, Sons of Confederate Veterans
    The Ancient Order of Turtles
    ARRL, SPAR, Six Meters Worldwide, Chattanooga ARC
    ARRL Accredited VE
    Re: Need nut, bolt, washer specs for Rohn 25 tower
    At a minimum I would go with Grade 8 stainless. I have an area friend - Marty, N8XPK - who is a tower rigger. You might try getting in touch with him (bakertower_atsign_neo.rr.com) and asking his advice. Tell him I sent you.
    May 2007
    Yep.. Just grade 8 stainless. Lock washers and anti seeze will do ya just fine.. You don't need to buy them from Rohn. Call around, You'll find the best price. www.winetwork.org Len will tell you more info you need to know. His email is on the website.
    Dec 2009
    I figured Grade 8 stainless, but there are two sizes of bolts. Anyone know the size and length of the bolts?
    73 de Richard W4RLR
    Southern born,
    ARRL Accredited VE
    May 2007
    It should say on rohn's site. If not i'll find out for ya. I work with three tower guys here. I should say i'm there weather man slash lightning detector. 3/8 corse thread with 1/2 inch heads 1 1/2 long comes to mind. But i'll find out forshure.
    May 2007
    OK Heres the deal From da tower man. 5/16 fine thread 1 1/2 long is the one size and the other is 1/4 fine thread 1 1/2 long. He says don't waste your money on stainless. Reg Grade 8 is just fine. Lock washers and a dab of anti seeze so it comes apart in the future. Also knock the burrs and galvanizing out of the holes with spud pin.
    Dec 2009
    Quote Originally Posted by N9FE
    Thanks! I go to Ace Hardware tomorrow! As they say in Germany, donkey shorts!
    73 de Richard W4RLR
    Southern born,
    ARRL Accredited VE
    SK Member (12/2/2011)
    Oct 2008
    Apison, TN 37302
    Quote Originally Posted by W4RLR
    Then it's off to Shakespeare for one of their big HF marine mobile antennas???
    Orca Whisperer kf0rt's Avatar
    Denver 'burbs
    Don't forget to lube the leg interfaces, too (where one section goes into the next).
    I forget what we used to use for that, but it'll make it a lot easier to get the sections apart years from now. Bit of axle grease, maybe? Sucks when you have to dig out a scissor jack to pry the sections apart.
    Forum Addict w3bny's Avatar
    Unless you need them like right darn now.
    I would buy in bulk from McBastard-Carr
