Results 1 to 3 of 3
Thread: tcl eggdrop scripting
    Is there already an animal for eggdrop that connects (via telnet) to a server, and echoes it into an IRC channel?
    I'm looking to write this script, but I figure someone must have done it already. If I need to, I'll hack apart a telnet library for tcl, but not looking forward to debug testing of it.
    Specifically, I'm looking to dump a dx cluster into an IRC channel, via eggdrop.
    Re: tcl eggdrop scripting
    ok, so I kind of got this working thus far:
    dxclusterbot.tcl
    Code:
    # dxcluster_bot
    # ver 0.1
    # kc2ugv 28 MAR 10
    # licensed under the GPL vr 2 or later
    # to connect to the cluster, issue a .cluster_connect
    # to disconnect from the cluster, issue a .cluster_disconnect
    set vDxClusterBotVersion 1.0
    listen 12345 script IncomingConnection
    proc IncomingConnection {idx} {
     #We've got a new incoming connection, hand it over to our "handler"
     control $idx IncomingTransmission
    proc IncomingTransmission {idx text} {
     #Did we recieve a new line, or did the remote end close the connection?
     if {$text != ""} {
      #Slit the text into a list and retrieve the command..
      set data [split $text]
      set command "write"
      #.. and see what we're supposed to do.
      #Hint: this would be a nice place to add a command for authentication...
      switch $command {
       write {
        #Use list-element 1 as channel, and the rest as the message to be sent
        #Considder adding a check whether the connection has authenticated or not yet.
        #Atleast we do check that it's a valid channel..
        if {[validchan [set chan "#testingdxcluster"]]} {
         puthelp "PRIVMSG $chan :[join $text]"
     } else {
      #remote connection closed, do some cleanup here if needed
      #Hint: here you would un-authenticate the idx (connection identifier)
      #For now tho, we'll just do a putlog for fun
      putlog "Remote connection $idx dropped"
    But, I had to hack it with Expect:
    Code:
    #!/usr/bin/expect -f
    spawn telnet dxc.ab5k.net
    expect "Please enter your call: "
    send "kc2ugv\r"
    interact
    And then this script, to put it all together:
    Code:
    #!/bin/bash
    ~/egg/eggdrop clusterbot.conf
    ~/egg/dxcluster_login.exp | nc localhost 12345
    Not pretty, but functional. It does what it's supposed to do. I know I can get that expect stuff into the tcl script somehow.
    Newbie F4GUG's Avatar
    Apr 2013
    Gironde (33) - FRANCE
    Hello
    I ask this day to dxsummit if they allow me to use their pages.
    http://hamradiochat.org/dxwatch-by-eggdropIRC.png
    I have an irc server under construction for hamradio and i prepare an eggdrop who (in futur) send by channel all spot by frequency.
    It is not perfect but i have just a last little problem before to have a good program
    I hope to create an attraction for our youth geeks to find new hamradio, It is too hard in France to found new OMs
    best regards
    GUG
    use a simple english please, TY
