Results 1 to 6 of 6
Thread: Doing It Yourself (repair and maint)
    So I asked a member here if he knew of any alignment videos already posted on the web and I went and looked on YouTube first.
    [youtube:3kb9si76]http://www.youtube.com/watch?v=i8IaUEhz17o[/youtube:3kb9si76]
    Pretty old school, pretty simple.
    I'd like to start a place here where we can share regular maint advice and anyone can add anything they have run into or just feel would be helpful. Video of the procedure is a plus.
    Re: Doing It Yourself (repair and maint)
    This stuff is Your Friend:
    A large number of "intermittent" problems (especially with older sets) can be traced to dirty potentiometers, switches and contacts.
    As with Brylcream, "...a little dab'll do ya".
    SK Member (12/2/2011)
    Oct 2008
    Apison, TN 37302
    More like a tiny dab. A guy at the Dalton,GA 'fest was telling me about his Drake R-4C problems and what he'd already done to "restore" it.
    So I ask him how red his 'glass wafer switch sections had turned after he "sprayed" them with Deoxit, he said pretty red. :roll:
    Orca Whisperer kf0rt's Avatar
    Denver 'burbs
    I was always told to use a swab and stay away from the sprays.
    Tiny 7.4ml bottle - $17.95.
    The spray is for flushing potentiometers and the needle-based applicator is for switch contacts, edge connectors and the like.
    That stuff has bailed me out of a LOT of problems.
    Oct 2008
    Apison, TN 37302
    DeoxIT is good stuff, if used properly.
    Never let the stuff touch a 'glass switch wafer section at all, especially on the edges where the 'glass fibers will soak it in like a sponge. It will clean off a ceramic switch section with little problem.
    Newbs generally cause themselves as many problems as they cure with DeoxIT.
