Results 1 to 10 of 18
Thread: 43 foot vert matching unit
    Forum Addict w3bny's Avatar
    Hiya folks. It's been an icky weekend but I was able to get some stuff done on my vertical. Not what I wanted to do (dig a trench, lay some conduit and run coax/control cables) but today was able to get something done.
    For those of you who dont know what I am up to, I took on building the AD5X 43' vertical 10/80M matching project as seen in the December/January issue of QST magazine (if you don't get QST, go to http://www.ad5x.com/images/Articles/Match160.pdf for all the details!) .
    Since it was so darn icky and I wasn't able to lay conduit or lay out radials, I decided to mount the box. I binked some pressure treat as verticals down with 1x2 cross braces. (I was going to dig a hole...but it was moosh so I took out my binker to whack them into the ground. Here is the overall view of the box as mounted and connected.
    As you can see, I decided to forgo the usual wiring convention and go off the deep end with 2" copper straps. No, they are not from Georgia Copper, I made them! I started off with some copper flashing that I had gotten from Dyson's (a local mom-pop hardware store) a while back. Took my handy-dandy IR pneumatic sheers and WHRRRRRRRR I now have a 2" strap as long as I need them. So, why copper straps instead of wire or braid? Simple. Copper strap provided a greater surface area then wire. And since we are dealing with RF and the surface effect (RF tends to hang out on the surface of cables) so I gave the RF a larger surface to travel along and provide a lower impedance for the RF to travel on vice the braid or 2Kv wire that I may have used. (side note: I changed out the braid that I was using on my SGC-237 coupler on my truck for a 2" wide copper strap. ZOMG!!! Big difference! Coupler takes oh...about a second or less to tune up on all frequencies above 80m. 80 is still a bit persnickety...but hey..Im trying to load up a way short antenna on 80! But it still loads!) Here is a side view of the box.
    Now...why is that copper so pretty looking...Blame the Navy and its 20yrs of programming (if its copper or brass...ITS POLISHED) Its not a mirror finish but its clean. And I expect it to stay that way for oh....10 years or so. How you ask...HEH...."Ancient Chinese Secret" (First person to tell me where that line came from...I owe you a soda at the least!) Actually its from a certain coating called PERMALAC. I saw it on an antenna page and was impressed with its properties (copper protection and general UV protection). Be advised though. THIS STUFF AINT CHEEP! A spray can is 21 bucks and 10 bucks for shipping! You don't want to know what a gallon of the stuff costs...so use it sparingly! Want more info? http://www.permalac.com/ So the bulk of it is permalac'd...except for the connection points. They are clean copper...albeit with a coating of conductive copper laden grease (got it from ICE suppressor folks). Here is the side view of the connections...
    And here is another connection point view with a gross view of the connection to the DX engineering radial plate
    Here is the connection to the antenna itself.
    Here is a close up of the mating to the radial plate. I left...2 inches un-protected and I coated it top and bottom with conductive copper grease.
    And mounted it on four points with star washers (top and bottom) stainless steel 1/4-20's and flats/locks. Yeah its over kill but you cant tell me that there isn't enough surface area mating the copper to the radial plate!
    And here is the box and antenna...as seen from the side.
    And that's what I did today. I probably wont lay conduit or radials next Saturday (Church stuff) but will probably do something Sunday.
    If you guys have any questions please...feel free to ask. Otherwise...
    Thanks for letting me take up your Sunday evening.
    P.S. IOU pics of the inside of the box.
    Snarky Dick ka8ncr's Avatar
    May 2008
    Re: 43 foot vert matching unit
    That's some fine professional looking work.
    When I was much younger and hanging around AM stations, we never worried too much about the look of the copper. We did apply a weatherproofing monkey snot over connections that were not soldered, but I have to admit the shiny copper looks quite nice and tidy.
    What are you going to use to slit the earth for the radials? I found a used electric chainsaw at a garage sale, found it to work like a champ for radials.
    Nice project and chainsaw FTW!
    Master Navigator KC9ECI's Avatar
    Wiscowsin
    Calgon. You owe me a soda Bunbun, but I'll take a beer or a Scotch. I'll be at Dayton 2011.
    Quote Originally Posted by KC9ECI
    Not making the trip this year, Tom?
    The time and preparation put in the antenna system will be well invested m8.
    Better do it good the first time, my 160 and 40 meter vertical now has about 1000 feet of copper wire as counterpoise.
    Running everywhere i saw chance to put a wire away in any form or shape.
    Mind you we have good soil here, always wet and conductive.
    Mine is 45 feet high, fed at the base and partly helically wound and a T of 2 x 40 feet wires on top as C.
    I connected everything i could find of metal to the ground system, the house ground, the satellite mast, ( dug in 8 feet in the ground) etc.
    A 100K pressed carbon resistor between radiator and ground takes care of the static charges.
    I can run 1 KW in it with no problems here with people's gear, as i can do on the other 2 H.F. antenna's.
    I think this summer i'll try a T400-2 torroid, 1:4 UnUn transformer and a autotuner directly at the base.
    Fed directly it is resonant at a wide area round 1850 and also does well on 40 meters.
    The rest of the bands sucks... :roll: , then i build it originally for 160 only... ;)
    Good luck with the radials, nice piccies and set up though ;)
    WINNER! And dont expect that top shelf stuff... Its class 2/NEX scotch for you!
    Radials...yeeah.... I have ripped up the old crap that I thought was a radial field (about 500') and have 60 43' radials ready to be installed. BTW...that's 2,580' of #14 ready to be laid down. And each mounting point crimped AND soldered thank you very much.
    As for laying them or burying them. PEH!! surface mount and landscaping pins. Thats why I have to work quickly. I have to get them down before the "lawn" (cultivated weeds more like) wakes up. Once they are down the grass weaves over them and you will never know they are there. And let me tell you...they were a beehatch to get up!
    I wish I could elevate them up a foot but alas...I do like going out back every now and then.
    More later!
    Don't use normal solder, it will turn to white powder within a few years
    Cadweld, silversolder etc, and even then protect the weld.
    Paved my backyard, so all the radials are under the pavement, 2 " below the pavement.
    Front garden, used your method, just let the grass grow over it.
    The rest of the garden, used old large metal saw blade, "scratched a small v 2" deep, wire with pegs in it, use size 13.5 shoes and 250 pound body weight, done.
    :rofl:
    In total 12 rods 10 feet long are the safety ground, less as 0.14 ohm ground resistance measured by the electricity tech, also part of the .radial field.
    Our scrap metal firm had some nice old copper which i bought for scrap metal price, and a large cake.
    Never saw someone so surprised and doubting his expensive megger, till i told him why i had such low value.
    Soil here is young silty seaclay. ( this was part of the sea till 1810....)
    All copper wires are bare, 3.2 mm thick.
    8)
    Quote Originally Posted by PA5COR
    :rofl:
    Now you tell me. Too darn late now. wait....hmm.. permalac and adhesive heat shrink? dunno. Now Im going ot be loosing sleep over this.
    Fertility Shaman N5RLR's Avatar
    Dallas, TX USA
    Excellent work, Ren.
    Quote Originally Posted by w3bny
    Now you tell me. Too darn late now. Wait....hmm. Permalac and adhesive heat shrink? Dunno. Now I'm going to be loosing sleep over this.
    Eh, make as clean & tight a connection as possible, weatherproof it as best as possible, then keep an eye on it. No problem.
    73 de Mike, N5RLR
    "I drink for the honorable purpose of getting bagged." -- Jackie Gleason
    "It is my belief...that the truth is generally preferable to lies." -- Albus Dumbledore
Similar Threads
  1. Which Foot Warmer?
    By W9PSK in forum Questions & Answers
    Last Post: 04-13-2010, 11:02 AM
