Hi Guys. Ain't been on the island for a few months. Been busy with work and other projects and issues.
Got a question that is sort of ham related. I have in my truck a 100W 12vdc to 120vac power inverter. I use it to charge my cellphone as my cp has an issue with standard 12vdc cigar lighter plugs. (Samsung Moment with Android 1.5 from Sprint). The power inverter works well. The issue I am having is this inverter is a very noisy piece of equipment. It's putting buzz in all my audio stuff I have in the truck. My 2m rig, my truck stereo, my phone audio when i play mp3 files with it etc. I know I can get toroid cores to fight the issue but I am uncertain which type to get. I know i need to get the snap on ones in plastic cases as I will be putting them on power lines and speaker lines.
What sizes do I get? and does anyone have any links to a preferred supplier? Which lines do put them on? I have a standard audio patch line 3.5mm stereo male plug on each end that i run from phone audio out to aux input on the stereo. Do i put a TC on that line? I figure I should put one on the power cord leading from the 12v cigar port, one from the power inverter to the phone. What about the stereo speaker/power lines? Do i put one around the bundle where it leaves the back of the stereo? (if i can even get to it, it's locked behind the dashboard where the company says NO GO) I know i should put one around the power line to the 2m rig.
I do know one thing that is a major part of the problem but I can't change it. The location of the power inverter to the stereo. The inverter is in a little cubbyhole directly underneath the stereo. there is about 4 inches of empty space between inverter and stereo. This is where it has to stay as I need to keep my phone on the charger at all times due to extremely poor battery life issues. My phone has to stay by me as dispatch calls me frequently for updates on work. This phone eats battery life like it was a starving man at a buffet. Battery life is about 2 hours from full charge to fully discharged and the phone turns off. This is the 4th battery for this phone and it's a known issue according to Sprint. In retrospect, the toroid cores may not be the answer to my problem. Is there a way to shield this power inverter to prevent it from emitting interference?
Any input will be appreciated. Thanks. I can answer any questions when i get chance to get online again which may be a few days.
Thanks
Brian/N2NKW
