Page 3 of 463 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 4621
Thread: Random Thoughts
    Re: Random Thoughts
    ^gently removes bong from upper shelf and places beside floor monitor^
    SK Member 5/14/15 rot's Avatar
    Henderson,NC
    Re: Random Thoughts
    Careful with them RT's
    rot
    "In the field of opportunity, it's plowing time again."
    N.Young
    Orca Whisperer kf0rt's Avatar
    Denver 'burbs
    Re: Random Thoughts
    Quote Originally Posted by WØTKX
    Oh, that sucks. I love Yamaha audio gear. Got me a CR-600 "Natural Sound" receiver in the living room.
    Not using the amp section, I run a little T-Class amp to the speakers.
    Know anybody in Phoenix? http://phoenix.craigslist.org/cph/ele/1616466018.html
    Same here. Got three Yamahas now; newer than your CR-600, but still great stuff. RX-V1800 runs the living room and garage. Love it. Just put an RX-V465 5.1 system in the shack over Christmas - present to self, and too [strike:1bvfjbxf]cheap[/strike:1bvfjbxf] inexpensive to resist. Old RX-385 stereo RX in the exercise room (yeah, right) still churns out tunes once in a great while.
    And before you say it, I threw the old IC-228A on the desk here last weekend. Still works. :)
    Re: Random Thoughts
    Well the damn shaft is so hard to turn that I don't even want to use it but, it is the best receiver for FM that I have. I'll open it up again and see if I can booger up a solution. I'm sure it won't turn smoothly afterwards, but I'm sure it will turn easier.
    What the hell would make it want to damn near lock down? There is no way to adjust the drag or tension. The bearing or liner or whatever it is, looks to be that white plastic looking stuff that is usually nylon.
    It was working perfect one second, the the next time I went to turn it ... WTF? I use it to DX so turning the dial is an absolute must. Right now, it's a knuckle buster.
    Re: Random Thoughts
    So, I've worked the bearing loose with some sewing oil. Still kind of stiff but not impossible. The flywheel isn't going back on, there's no point. Restrung everything nicely.
    The meter lights were 15VAC. I used 4 LEDs out of an LED floodlight that failed due to other parts to make a rectifier and connected 4 ultra-white LEDs to it. One for each meter and I placed 2 on the tuning slide. It isn't perfect on the slide. I'm not going to break it apart. I think the replacement was the slide with an embedded bulb as one single unit.
    And now the pic: I put the little green bulb rubbers back on for the meters.
    Re: Random Thoughts
    Love that dial, tru sliderule.
    The amp I run is one of these, in a newer style case... http://www.tnt-audio.com/ampli/t-amp_e.html
    Very clean sounding, for cheap! Can also be run portable with batteries...
    Add speakers and MP3 player, better than a boombox!
    SK Member Feb 2017 W4GPL's Avatar
    Jan 2008
    DM79ms
    Re: Random Thoughts
    What's worse? Driving a cab or agreeing to fix people's spyware problems?
    Driving a cab is probably dangerous, very little money in it..But it's not fixing Windows.
    And I'd have to supply my own keyboard, because you know they're not getting those spyware whatnots from just anywhere. Ewww...
    Re: Random Thoughts
    I want my Maypo!
  9. #29
    Re: Random Thoughts
    You know the knob had to crap right after I put up a new ant I boogered together with ordinary household items. I think I'll add a third element to it.
  10. #30
    Forum Addict w3bny's Avatar
    Undisclosed solar powered burrow in Southern Maryland
    Re: Random Thoughts
    Poop spelled backwards is poop.
    Yeah...I'm a furry...Deal with it!
