Results 1 to 8 of 8
Thread: 2m Stealth
    2m Stealth
    The tree has grown a foot since this was taken and these antennas are much less than obvious. The height is about 15m/50ft.
    At the top is a Hentenna & reflector, you could call it a 2-element but it has more gain than a Yagi, and below a double 2-element Quad using a common reflector. I have no need for a rotator because in the missing direction is a 200ft cliff. The materials are 10mm/0.4inch copper which darkens with age, SRBP plates and terminations in a small ABS box with a lid.
    Grand Exalted Poobah WV6Z's Avatar
    Sep 2007
    Oh no, I'm still on that feckin' island!
    Re: 2m Stealth
    Very well done Hugh! Magnificent actually! :shock:
    KD8EFQ ~ "With MFJ one might as well stand outside during the worst possible calamity and wair for death."
    Re: 2m Stealth
    I like the look so far but do you have bigger pics?
    Re: 2m Stealth
    When the tree flowers with lots of pollen and sap, does it change your RF radiation?
    Re: 2m Stealth
    Good question. Does it heat up enough to reodorize the area under such conditions?
    Re: 2m Stealth
    Your holiday signal is 5x9 with a scent of PineSol! :rofl:
    Re: 2m Stealth
    The tree smells good in warm weather, not like so-called "pine" scented disinfectant, and it exudes resin. I tried it as solder flux, it works well.
    I'm not aware of any power loss, the Hentenna was good for an opening to the south of Portugal (5+9+), that's about 1100 miles using 30W, a few weeks ago, there's a bundle of coax down the tree and a switch for antenna selection in the shack. As far as heating goes I won't get much from 100W but I did take the precaution of moving the garden machinery fuel from the adjoining shed to a safer place.
    Re: 2m Stealth
    Wouldn't it be a bit acrid as an electronic solder flux not to mention possibly dealing with stringy trails everywhere like a hot melt glue?
