Linux Fedora 25 login screen loop
Saturday I went to wake the machine up and got no response.
Did a hard reboot, took some time to reboot, but it eventually recovered and came up and seemed ok.
Received a system notification Sunday morning about low disk space.
Logged in and found /home at 100%, never a good thing, tried running: sudo du -sh /* to see if I could locate the offending dir(s)... no luck, just a lot of "permission denied".
Thought maybe a reboot would restore sudo, that's when it went south real fast.
Apparently there is a GRUB login loop issue that may occur when Xwin system crashes while a sudo command is in progress (but I think F25 uses Wayland so not sure if it's still the case?).
I can select the user, type in the password, it looks like it's logging in, but returns to the userid screen.
I'm assuming the first unresponsive episode Saturday is what started it.
Can't really find a fix for it at the moment, and the couple fixes I did find are over my head... so I guess I'll rebuild it.
Luckily everything is backed up nightly.
If you're read this far, sorry for the ramble, but that was the low point of my weekend, did get some antenna wiring done and a lot of yard work before it got hot.
Ok, now where did I put that F25 usb iso?
Dan
<sig section under construction>
