off centre fed wire antenna
hi!
I want to build a "long wire" type of antenna - really an off-centre fed antenna - 34m one side 7 m the other (approx). According to MMANA this should give me a feeding point of 180 ohms and a very adequate gain and direction of 14MHz and 7MHz. The wire to be used is 2.54mm insulated household wire (#10 wire).
Questions:
1. I am thinking of building a home-built ladder line for this antenna made of the same wire (#10 wire - 2.54mm = 1/10th of an inch diameter copper wire) about a pencil thickness apart (roughly 1/4") which I think should give me 180 ohms or near that. Can somebody confirm this please?
2. I am not sure which kind of toroid to use. If I superglue 2xFT240-52 toroids together and wind 5 turns primary and 18 turns secondary (to get the 50:180 transformer needed) on this superglued toroid core, using the same #10 wire, how much wattage roughly will this transformer withstand?
thanks to all who will answer and best 73s from
Joe, 9H5JO
